crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Cycliq Fly6 CE Gen3crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Cycliq Fly6 CE Gen3 Teardown, Opening the housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cycliq Fly6 CE Gen3 Teardown, Opening the housing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cycliq Fly6 CE Gen3 Teardown, Opening the housing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The housing is held closed with four crosshead screws, each hidden behind little rubber bungs that ensure the unit is watertight. Screw locations are shown in picture 1, dig out screws using a spare pentalobe screwdriver (picture 2), and remove screws using a Philips #00 screwdriver. A paper clip could also work for picture 2.
  2. Cycliq Fly6 CE Gen3 Teardown, Opening the housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cycliq Fly6 CE Gen3 Teardown, Opening the housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cycliq Fly6 CE Gen3 Teardown, Opening the housing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the light on it's side (picture 1), peel back the sticker (picture 2), and open the housing (picture 3).
  3. Cycliq Fly6 CE Gen3 Teardown, Separate battery connectors: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery and set aside (picture 1) to test its voltage.
    • Rather than test the voltage, the first time I unplugged the battery I immediately plugged it back in, powered it up, and found it had 100% charge.
    • Seconds prior to completing the above task, the battery had been stuck near 18% charge for weeks. Exposure to cold weather and potentially moisture at the battery connectors potentially played a role in this light's temporary demise.
  4. Cycliq Fly6 CE Gen3 Teardown, Grease battery female connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cycliq Fly6 CE Gen3 Teardown, Grease battery female connector: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cycliq Fly6 CE Gen3 Teardown, Grease battery female connector: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place some dielectric silicone compound with a pentalobe tool (picture 1), place grease on top of female battery connector leads (picture 2), and press male battery connector on to female leads.
    • If detaching/reattaching the battery connectors or greasing the battery connectors improved your light's function, repeat steps 1 through 3 in reverse. If not, consider replacing your battery as shown in step 5.
  5. Cycliq Fly6 CE Gen3 Teardown, Replace battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cycliq Fly6 CE Gen3 Teardown, Replace battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove foam covered plastic caps from ends of battery and save for later (picture 1). Replace existing battery (picture 2) with equivalent. To install new battery, you may need to cut wiring harness from existing battery and solder it to new battery.
NorthernBigDummy
crwdns2935283:008/25/15crwdne2935283:0
342 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Good article. I’ve tried to get a new battery but cannot find one any ideas where to get one from
Bob m - crwdns2934203:0crwdne2934203:0
@bobm85679, I'm sorry, but I don't know where to source a replacement battery. If the battery in my light requires replacement, I might try repurposing old vape batteries.
Are you sure your existing battery requires replacement? The battery should likely last between 500 and 1000 cycles. As discussed above, dielectric silicone compound makes and preserves a better connection between the battery and the light's PCB, something in my opinion should have been included from the factory for a device that was designed to be used outside and cycle through different temperatures.
NorthernBigDummy - crwdns2934203:0crwdne2934203:0
The battery appears to be specially made for Cycliq. It comprises 2 cells running in parallel - a bit naff. If you can find a thin Lipo cell 50*25*5mm you could also run them in parallel. I haven't had any joy finding a solution either.
scouser - crwdns2934203:0crwdne2934203:0
@scouser58262, thanks for contributing this. Seems Cycliq wanted to boost the battery amperage by running the cells in parallel? Seems odd they didn't go with a single bigger battery?
In my opinion, Cycliq should have picked a battery system with an even greater amperage as I've noticed the light occasionally shuts off when the phone app connects to it via Bluetooth (and the light and camera simultaneously running). To avoid these shut-offs, I turn off video recording and the LED light if I expect to spend a longer time configuring the light/camera in settings while using Bluetooth. I expect my strategy will no longer work as the battery ages and the peak amperage it can provide declines.
Thanks, this worked a treat for my CE603. Bit of a joke that Cycliq don't service these and merely offer discount on a new one.
99p for 3 tubes of dielectric grease means I saved £100s
John Darley - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 846
