Ding-dong, the dongle's here! Google knows that cat videos are more entertaining when viewed on a 72-inch HD display, so they packed Chrome into a compact dongle, threw an HDMI output on it, and provided the world with the cat videos we deserve! Join us as we tear down the Chromecast to find out how Google squeezed so many cats into one small package.
Want to stay in the loop with our most recent goings-on? Follow us on any or all of our social media outlets! Fixin' for some filters? Instagram it is. More of a text person? Twitter! Enjoy compound words? Say hello to Facebook.
Upon eagerly ripping open the Chromecast's box, we are greeted with more than just a dongle.
The dongle's specs and features:
1080p HDMI output
2.4 GHz WiFi 802.11 b/g/n
1080P maximum output video resolution
USB-powered
Compatible with a variety of devices, including both iOS and Android devices
The Chromecast's sole port is the USB charging port. As if TVs don't have enough wires already, your favorite new dongle requires external power via USB.
At least Google sort of mentioned this…
No, the USB is only required if your HDMI input will not supply enough power over the HDMI 5v line, see http://www.hdmi.org/learningcenter/kb.as...
HDMI Sink Devices (like TV's) aren't the one's providing 50mA power, it's the source device. In this case, the source device is the Chromecast. Sorry but you likely need the USB power unless your TV is not following the HDMI spec.
I would like to make a costum case with better heatsick for that fun diy project
What's the current rating on the power adapter? Regulation?
What's the current draw when idling, and when streaming?
Thanks
At 4.8 volts I'm showing 315ma streaming and 240ma (when the background picture changes
it peaks closer to the 300ma figure in standby.
Model Number: H2G2-42.
We see what you did there, Google. Your clever nerd humor will not be lost on us!
Call us speculative, but it appears Google thinks this device is the answer to life, the universe, and everything.
crwdns2935267:0crwdne2935267:0Heat Gun$24.99
To our relief (and maybe a little disappointment), it seems as if we won't need to pull out the big guns to get this little guy open.
A plastic opening tool exploits the seam of our dongle, and just like that, we can start pulling out components.
The first thing out is, well, everything. Pulling the motherboard assembly out of the Chromecast leaves us with an empty shell.
Almost empty, that is, except for some excessive thermal leftovers and a big hunk of aluminum heat sink.
I managed to bend the HDMI plug. The device has stopped working. Any advice in how to realign it please ?
Mine also got bent, and thus the metal housing broke off. It still worked, but eventually one of the pins housed inside of the Female HDMI Jack Socket (the black plastic part) got bent. Now when connected it still works, but seems to abort the streaming due to that pin being bent all the way back. I wish there was a full teardown guide, because contrary to the author’s opinion, the HDMI Jack socket can definitely be repaired, and thus it can be brought back to life.
The central nervous system:
AzureWave AW-NH387 802.11 b/g/n WLAN, Bluetooth and FM Combo Module
Marvell DE3005-A1 System on Chip
Micron MT29F16G08MAA 16 Gb (2 GB) NAND Flash Memory
Micron D9PXV 512 MB DDR3L SDRAM
Interesting OOTB capabilties such as Bluetooth, FM etc. May be they get enabled in the future.
Do anyone know which supplier produces the 30pins BGA connector on the Chromecast?
The USB connector dismounted (aka "broke off") on mine. Appreciate the teardown photos. About to perform surface mount surgery under a stereo microscope. "No user serviceable parts inside" is really just a suggestion... LOL
Hi there how did it go with this fix?
With the motherboard out, only one component remains: a (relatively) ginormous heatsink. Made of solid aluminum and spanning the entire length of the device, it rests—lifeless hardware in a tiny coffin.
We can't say we're surprised, though, as the product information states "Chromecast may get hot to the touch; this is normal."
This is somewhat disconcerting, sort of like "melt in your hand, not in your mouth," or "side effects may include death."
We’ve decided not to assign a repairability score to the Chromecast.
There’s just nothing in it to repair. The Chromecast is essentially a luxury item with a limited use.
I want to repair the HDMI port
same that bich bent and broke like a ^!&$@*%%$%*^
You can buy or source HDMI ports from old cables and carefully solder them on!
crwdns2947412:027crwdne2947412:0
HDMI 1.4 can power the device without USB power.
Thanks, that's great to know..
This is incorrect, people have tested this and it doesn't work.
Dongle, dongle, dongle... yes, it is a fun word to type.
Any warning which includes the phrase "this is normal", clearly indicates something which any normal person would realize is not normal.
Next teardown a Galaxy Minstrel .... or was that just a British thing? They don't melt in your hand (according to the advert anyhow) www.youtube.com/watch?v=R8ggWmC_Cpg
Bees -
Very very interesting design. Lots of somewhat surprising things! In particular, TSSOP flash was a little unexpected... I don't suppose you guys still have one around to try ripping the flash off of to see if there are BGA landings under there?
Other aggressively cost-reduced NAND consumers (i.e., USB thumb drives and SD cards) often have landings for both BGA and TSSOP flashes so that they can quickly change to whatever the cheapest source of NAND flash is that day without having to spin a new SKU of their board... would be interesting to know if Google did the same here.
All HDMI 1.4 is HDMI 1.3c but listed on the HDMI web site. So tell me just how that makes it capable of powering devices? Magic perhaps? :)
P.S. H2G2 is not a reference to Hitch-Hikers Guide to the Galaxy. HHGTTG is.
This is a fantastic device.
Imagine being able to wakk up to any TV and watch your content or display map/location.
Add a touch sensitive display and you've got one heck of a tablet!
H2G2 is a reference to the Hitch Hiker's Guide The Galaxy, see http://www.h2g2.com
Doesn't the AzureWave AW-NH387 use the Marvell 8787 WiFi device?
Would like to see an analysis of the WiFi antenna used.
The antenna is a PIFA integrated as part of the copper on the PCB. You can see it just above the AzureWave chip where there is cutout from the metal shield. PIFA antenna general have best performance by pushing against the ground plane, thus the bigger the ground plane the better. The HDMI ground should provide a ground plane to the entire TV.
Tat Huen -
Does anyone know who makes the two power regulator chips they are using on this design? I believe this would be the two small square chips marked WRVL-686B-311GAE and WRVL-21AA3-246GAO?
It is my understanding that HDMI1.x sink ports will not supply power out of the HDMI port, only MHL enabled HDMI sink ports can do this. If someone has a pointer in the HDMI spec that says anything about sinks putting out power then please share the reference.
Perhaps these are MRVL instead of WRVL, which would make them Marvell chips?
Marvell does make switchers:
The nerd humor continues if you look at the model number of the power adapter it comes with - "MST3K-US".
I just stumbled on a feature that I have not seen mentioned anywhere. I have a Logitech Revue attached to my TV and to my network. When I play a YouTube video and hit the chromecast icon, I get the choice to cast to my chromecast dongle, my own device (laptop) or my Google TV. I just disconnected my googlecast dongle from my TV and still get the option to cast to my Google TV and it works just like I was broadcasting to the Chromecast dongle. At least some of the required drivers must be present in my Revue. Cool! Maybe I will be able to use the Revue instead of a dongle on this TV.
It's too bad the author denied two edits that state that the device can be powered by the 5v line on the HDMI 1.4 input instead of via USB. Even Google states this.
A per numerology, the word CHROMECAST is 42. (3 8 18 15 13 5 3 1 19 20) -> (3+8+9+6+4+5+3+1+1+2=42)
HHGTTG isn't a H2G2 reference. Nice, if a somewhat obvious, try though.
Does the Marvell chip drive out HDMI ?? The AW-NH387 does not seem to have a HDMI output. I wonder what component drives out the video/audio on HDMI.
No, the AW-NH384 is a WiFi module.
The Marvell DE3005-A1, otherwise known as the ARMADA 1500-mini, drives out the HDMI.
Verk -
Hello, somebody know thr part number of the U13?. is the yellow one at the left near the usb
How to fix the charger port
good day,
someone could facilitate logical circuit plane Chromecast Teardown?
The only USB port on my TV is for 'Service Only', hmm. Looks like I might have to use a USB plug for this.
I have bought a used Chromecast key and the gold metallic part where we insert the key is missing. Any possibility to find one and put it back on it?
