Charge 3 Disassembly
  1. Charge 3 Disassembly, Strap Connectors: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Strap Connectors: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Strap Connectors: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove both T3 screws
    • Slide off the plastic piece by lifting out and then up
    • Slide plastic and spring assembly off the rail
  2. Charge 3 Disassembly, Display: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Display: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Display: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat the glass screen with a blowdryer to soften the adhesives
    • Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there
    • Insert a razor blade between the glass and the body
    • Keep going around the rim of the display until loose
  3. Charge 3 Disassembly, Cable Warning: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is how close those cables get to the edge underneath the Fitbit wording so be careful
  4. Charge 3 Disassembly, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift display up gently
    • The battery is attached with a little bit of adhesive so lift gently
    • Remove battery connector
  5. Charge 3 Disassembly, Vibrator Shield: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Charge 3 Disassembly, Vibrator Shield: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both T2 screws
    • Liftoff metal shield
  6. Charge 3 Disassembly, Main Shield: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Main Shield: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Main Shield: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two T2 screws
    • Remove T3 screw
  7. Charge 3 Disassembly, Display Connectors: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Display Connectors: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Display Connectors: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Liftoff both display connectors
  8. Charge 3 Disassembly, Disconnect Connectors and Altimeter: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Charge 3 Disassembly, Disconnect Connectors and Altimeter: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect vibrator motor
    • Disconnect heartrate and charging connector
    • Remove altimeter
  9. Charge 3 Disassembly, Side Button and Vibrator: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Side Button and Vibrator: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Charge 3 Disassembly, Side Button and Vibrator: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove button assembly from case
    • Remove vibrator motor
    • Has a slight bit of adhesive and is magnetic to the case
  10. Charge 3 Disassembly, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Charge 3 Disassembly, Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove motherboard
    • It seems as if the heart rate sensor and charging pins are molded into the case, and I was not able to remove them
ShellingRook27
crwdns2935283:008/21/19crwdne2935283:0
1,790 crwdns2915208:0crwdne2915208:0
Repair For You crwdns2935289:0Repair For Youcrwdne2935289:0
Business
crwdns2935297:011crwdne2935297:0
crwdns2944067:012crwdne2944067:0
The tear down pictures are great, but in my Charge 3 I needed a T-1 and a T-2 driver
Julien Baldwin - crwdns2934203:0crwdne2934203:0
Same, my ifixit pro kit only had a driver for the external screws and did not come with a small enough driver to remove the screws inside the charge 3 unit. I'll need to get the smaller bit from a different kit.
Brian Hall -
Which step in the teardown guide needed the T1 driver?
ShellingRook27 -
Great job on this tear-down. Thank you, it really helped in my screen replacement.
AndyZ - crwdns2934203:0crwdne2934203:0
This tear down was very easy to follow. The heart rate monitor was also sealed in with some adhesive for me too but a little heat gun took it right off. I had suspected water leaked in and that in fact was the culprit after inspecting the connection. corrosion all around the HR monitor.
Nick Herbert - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 198
crwdns2942667:0crwdne2942667:0 9,064
