crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Casio CGP-700crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Casio CGP-700 Teardown, Tools/Hardware: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio CGP-700 Teardown, Tools/Hardware: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio CGP-700 Teardown, Tools/Hardware: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • See tools needed for disassembly
    • There are 5 types of screws to remember where they go back in place
  2. Casio CGP-700 Teardown, Remove keyboard from base: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio CGP-700 Teardown, Remove keyboard from base: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio CGP-700 Teardown, Remove keyboard from base: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove from base. 4 screws on corners. Disconnect speakers from base.
    • Flip keyboard over.
  3. Casio CGP-700 Teardown, Remove Back Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio CGP-700 Teardown, Remove Back Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio CGP-700 Teardown, Remove Back Screws: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the square tube support first
    • Remove all visible screws on the back
    • Underneath tabs, use a magnetid screw driver to remove screws inside the keyboard body
  4. Casio CGP-700 Teardown, Remove Side Panels: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio CGP-700 Teardown, Remove Side Panels: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove side panels on each side
    • Use both hands to pull it out, prying one side at a time
  5. Casio CGP-700 Teardown, Remove pitch slide, headphone jack from left panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio CGP-700 Teardown, Remove pitch slide, headphone jack from left panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio CGP-700 Teardown, Remove pitch slide, headphone jack from left panel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove ribbon from circuit board. Untape ribbon cable from side panel
    • Use a small screw driver to remove screws on circuit boards
  6. Casio CGP-700 Teardown, Remove top panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio CGP-700 Teardown, Remove top panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio CGP-700 Teardown, Remove top panel: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully flip the over the keyboard while holding it together
    • The top panel should easily lift up without force. Otherwise check for screws in the keyboard
  7. Casio CGP-700 Teardown, Inspect circuit boards: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio CGP-700 Teardown, Inspect circuit boards: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inspect for defective parts
    • Replacement boards available online
jfar
crwdns2935283:005/11/19crwdne2935283:0
385 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Bonjour, beau travail. Si vous continuez le démontage, de grace montrez le mécanisme d’action du clavier. Ce clavier est très bruyant lorsque la touche revient en position et il n’est pas évident d’isoler la source de ce bruit. Si le défi vous intéresse, vous pourriez indiquer comment atténuer ce bruit.
Félicitation pour votre travail.
JCaron
Jacques Caron - crwdns2934203:0crwdne2934203:0
Not many videos on disassembling the Casio CGP-700. This is a really good digital piano. The only problem is the noisy keyboard. When a key comes back in position you hear a loud noise. If you could show the action mechanism with the weight in detail, I,m sure we’ll be able to find a way to silence this keyboard.
JC Murdak
Hi Jacques, I’m looking back when I created this, but I don’t have any pictures of the action mechanism to help out with this. If someone else would like to add them, I’m sure this would be helpful. There’s probably room to double up on the felt or something similar inside of the keyboard if this is a concern.
jfar - crwdns2934203:0crwdne2934203:0
Hi,
The Touch Panel Control on Casio CGP700 is damaged, has anyone got details or part number of the same so i can buy. This detailed brakdown is very helpful. Thankyou.
vinoj k - crwdns2934203:0crwdne2934203:0
This s casio part 91087245119. Search google.
Michael Rosen - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2942667:0crwdne2942667:0 1,487
