Open battery cover and remove AA battery
Remove four screws from bottom part
Keep in mind: left lower screw have different long.
Separate top and bottom.
Remove battery cover from hole
Disconnect connector
Screw up four screws.
Desolder Red ground Pin. Hot shoe now can be removed
Remove Lock pin with spring. Don't miss them.
Remove four crews from bottom. Remove Shoe and remove metal shield.
Remove screws with springs
Now you disassemble hot shoe.
Next remove pins.
Desolid four pins
Remove PCB.
Volgens mij is stap 5 te vroeg afgebeeld. Ik moet de schroefjes van de metalen voet aandraaien, maar kan dat als alleen de rode groundpin is losgesoldeerd?
Hi mate @louisdederen
For removing hot shoe part you should desolder gnd pin and unscrew 4 screws over PCB, pins you may to remove in case if you want to remove PCB from housing
