REMEMBER to record (like, take photos of) screws you removed. Some are fine metal thread type and others are coarse self-tap for plastic. Do not mix them!
Canon EOS M5
Remove the strap, Or, it WILL cause mess during the teardown/repair. Remove it unless you are as SKILLFUL (lazy) as I am.
FIRST remove battery and SD card.
remove 1 self-tap screw
remove 6 screws
These 2
And these 4
Remove bottom cover
This is the NFC antenna(coil).
Left side:
Remove metal thread screw
Remove self-tap screw
Remove 4 metal thread screw.
Gently, lift (towards back) and slide the back cover towards left (THE LEFT when you holding the camera)
Disconnect 2 FPC.
The back case with LCD assembly.
The beautiful LCD FPC stretcher
We are in side the camera.
Remove 3 screws near the EVF. REMEMBER lengths and hole positions. The center one is longer. The left holes.
Pop the speedlight (flash)
Remove the screw covered by the speedlight.
Remove 1 screw in battery bay.
There's only one. Trust me.
Now the front case comes off.
There are some clips, be gentle and patient.
Please keep body cap on as possible, for shielding again dust.
Front cover comes off with 2 small parts. Don't loose them.
The capacitor
To avoid electric shock and damage, DISCHARGE IT with a 2kohm~10kohm resistor for more than 15 seconds, ASAP!!!
Right side, remove 1 screw.
Left side: remove 1 screw.
Remove 3 metal thread screw
Remove 1 self-tap screw.
Remove EVF plastic case.
There are some clips.
Remove 1 screw, REMEMBER from which hole!
Right side.: Remove 1 screw
Detach FPC.
Be gentle enough We do NOT remove top case. Because it's kind of messy with some adhesive...
When the top case is loosen. remove the metal frame.
Or you can remove this BlueTooth board if not being lazy.
IF you can count to 5:
PCB top left, detach 2 FPC. 1 ZIF, 1 non-ZIF
PCB top right, detach 4 FPC and 1 cable connector
PCB top center. detach sensor cable.
PCB right bottom.
Remove 1 screw
Detach 1 FPC
Detach 2 FPC
Ladies and gentlemen, the mother board
Digic and RAM
RTC battery
Some Flash
SD socket
Some power supply
EVF
Sensor assemly
Shutter assembly
crwdns2947412:010crwdne2947412:0
Anyone know where to purchase parts for the M5? I.e. Touch LCD assembly?
China’s market, they recycle broken devices and sells parts.
Terrance -
Thank You!!
Is there a way to remove and replace the rubber eye cup without disassembly?
I'm not quite sure, I sticks very tight. possibly glued or even moulded together
Terrance -
Does anybody know where to buy screws shown on step 6 or what size they are? One of those fell out of my camera.
As I measured, it smells like M1.7x0.35*4.5mm CM head. you can get away with M1.6x0.35x4.5 as they share same pitch 0.35mm, length 4.0 should also be ok.
Terrance -
Anyone know how to test if power is going out to LCD ? Or which diodes send power to the ribbon ? I’m trying to test if the LCD is actually gone or if it’s not receiving juice. Video finder works just fine and I can take pictures etc view them HDMI works etc everything works but LCD just black no matter what I do on the menu display functions. Before I spend money on a new LCD. Just wanted to make sure.
want to test power? just find big capacitors.
Terrance -
I've had a similar issue with the LCD screen. The backlight comes on but no picture. Everything else on the camera worked. I removed the camera's rear panel and re sat the LCD ribbon cable and control cable. Turned it back on and now the camera isn't coming on at all. I just get a green flashing light which stops after 5 seconds. Has anyone seen this before?
Yeah!I was able to fix! thank you so much.
My camera had a problem with the shutter button being half-pressed.
I removed top case, and disassembled, I found the shutter button was dirty.
Thanks to you, I was able to disassemble it safely.
Thank you, thank you thank youuuuuu!!!
