crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Canon EOS M5crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Canon EOS M5 Teardown, Remove Strap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Canon EOS M5
    • Remove the strap, Or, it WILL cause mess during the teardown/repair. Remove it unless you are as SKILLFUL (lazy) as I am.
  2. Canon EOS M5 Teardown, Bottom: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Bottom: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Bottom: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • FIRST remove battery and SD card.
    • remove 1 self-tap screw
    • remove 6 screws
    • These 2
    • And these 4
  3. Canon EOS M5 Teardown, Bottom Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS M5 Teardown, Bottom Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove bottom cover
    • This is the NFC antenna(coil).
  4. Canon EOS M5 Teardown, Back Case, left: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Left side:
    • Remove metal thread screw
    • Remove self-tap screw
  5. Canon EOS M5 Teardown, Back Case, right: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 1 screw.
  6. Canon EOS M5 Teardown, Back Case, back: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS M5 Teardown, Back Case, back: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 4 metal thread screw.
  7. Canon EOS M5 Teardown, Back Case, Detach FPC: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS M5 Teardown, Back Case, Detach FPC: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently, lift (towards back) and slide the back cover towards left (THE LEFT when you holding the camera)
    • Disconnect 2 FPC.
  8. Canon EOS M5 Teardown, The Back Case & Touch LCD.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, The Back Case & Touch LCD.: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, The Back Case & Touch LCD.: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The back case with LCD assembly.
    • The beautiful LCD FPC stretcher
  9. Canon EOS M5 Teardown, Inside The Camera, Back: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • We are in side the camera.
  10. Canon EOS M5 Teardown, Screw, Screw, Screw, Screw: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Screw, Screw, Screw, Screw: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Screw, Screw, Screw, Screw: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 3 screws near the EVF. REMEMBER lengths and hole positions. The center one is longer. The left holes.
    • Pop the speedlight (flash)
    • Remove the screw covered by the speedlight.
  11. Canon EOS M5 Teardown, More Screw, Battery Compartment: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 1 screw in battery bay.
    • There's only one. Trust me.
  12. Canon EOS M5 Teardown, Remove Front Case: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Remove Front Case: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Remove Front Case: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now the front case comes off.
    • There are some clips, be gentle and patient.
  13. Canon EOS M5 Teardown, Front Case and Inside.: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Front Case and Inside.: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Front Case and Inside.: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Please keep body cap on as possible, for shielding again dust.
    • Front cover comes off with 2 small parts. Don't loose them.
  14. Canon EOS M5 Teardown, DISCHARGE the Capacitor!!!: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When you see the speedlight resevoire capacitor.
    • The capacitor
    • To avoid electric shock and damage, DISCHARGE IT with a 2kohm~10kohm resistor for more than 15 seconds, ASAP!!!
  15. Canon EOS M5 Teardown, Metal Frame, left, right: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS M5 Teardown, Metal Frame, left, right: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Right side, remove 1 screw.
    • Left side: remove 1 screw.
  16. Canon EOS M5 Teardown, Metal Frame, back: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 3 metal thread screw
    • Remove 1 self-tap screw.
  17. Canon EOS M5 Teardown, EVF Case: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, EVF Case: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, EVF Case: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove EVF plastic case.
    • There are some clips.
    • Remove 1 screw, REMEMBER from which hole!
  18. Canon EOS M5 Teardown, Top Case, right: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Right side.: Remove 1 screw
  19. Canon EOS M5 Teardown, Top Case, FPC: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach FPC.
    • Be gentle enough We do NOT remove top case. Because it's kind of messy with some adhesive...
  20. Canon EOS M5 Teardown, Metal Frame: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Metal Frame: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Metal Frame: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When the top case is loosen. remove the metal frame.
    • Or you can remove this BlueTooth board if not being lazy.
  21. Canon EOS M5 Teardown, Main PCB, 11 FPC's: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Main PCB, 11 FPC's: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS M5 Teardown, Main PCB, 11 FPC's: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • IF you can count to 5:
    • PCB top left, detach 2 FPC. 1 ZIF, 1 non-ZIF
    • PCB top right, detach 4 FPC and 1 cable connector
    • PCB top center. detach sensor cable.
  22. Canon EOS M5 Teardown, Main PCB, more FPC's and screw: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS M5 Teardown, Main PCB, more FPC's and screw: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • PCB right bottom.
    • Remove 1 screw
    • Detach 1 FPC
    • Detach 2 FPC
  23. Canon EOS M5 Teardown, Enjoy (or Replace) the Main PCB: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS M5 Teardown, Enjoy (or Replace) the Main PCB: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ladies and gentlemen, the mother board
    • Digic and RAM
    • RTC battery
    • Some Flash
    • SD socket
    • Some power supply
  24. Canon EOS M5 Teardown, Under Main PCB.: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • EVF
    • Sensor assemly
    • Shutter assembly
    • Without proper measuring devices, I did not mess with the sensor assembly. otherwise the back focal will be ruined.
Terrance
crwdns2935283:011/17/09crwdne2935283:0
6,698 crwdns2915208:0crwdne2915208:0
crwdns2935297:018crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Anyone know where to purchase parts for the M5? I.e. Touch LCD assembly?
bflores - crwdns2934203:0crwdne2934203:0
China’s market, they recycle broken devices and sells parts.
Terrance -
Thank You!!
Is there a way to remove and replace the rubber eye cup without disassembly?
Donald Weldon - crwdns2934203:0crwdne2934203:0
I'm not quite sure, I sticks very tight. possibly glued or even moulded together
Terrance -
Does anybody know where to buy screws shown on step 6 or what size they are? One of those fell out of my camera.
Alexandr Kobzar - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 6,653
