crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Fancrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gather the required tools: a small Phillips head screwdriver and a smart wrench.
    • Make sure the device is unplugged and fan blade is not spinning before starting.
  2. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the clip-on stand that connects the fan. This can be done by hand.
    • Turn the fan so that the back is facing up and remove the screw on the upper part of the housing.
    • Remove the back casing to reveal the switch's screws on the inner part of the casing. Remove those as well.
    • The switch's settings:
    • Off (center)
    • Speed 1 (left)
    • Speed 2 (right)
  3. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the fan around so that the front is facing upwards. Remove the front grill by carefully popping out the edges from the plastic tabs around the enclosure.
    • Remove the fan blade by carefully forcing it off the motor shaft. It may help to use the wrench as a lever and slowly push it out.
  4. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that the blade is removed. The motor can now be removed from the other half of the housing.
    • Remove the two screws indicated in order to take the module out of the plastic.
    • The motor is connected to the blue transformer. The yellow and white wires indicate the two power outputs for the speed of the motor's rotation.
  5. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • That's it! There isn't too much when taking this device apart.
    • Note: You can further expand on the teardown by taking apart the transformer to DC motor set-up, but it's such a simple circuit that it isn't necessary to look at it.
Justin
crwdns2935283:012/08/14crwdne2935283:0
111 crwdns2915208:0crwdne2915208:0
Hi How do you find the replacement switch?
sadeyealso - crwdns2934203:0crwdne2934203:0
Hi, I was wondering where I could find a clip and base for a 6 inch fan. The fan itself works just fan. Preferably it should be an online store.
Thanks for reading.
Nova Apex - crwdns2934203:0crwdne2934203:0
Is it possible to purchase a replacement blade?
Wayne - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 4,702
