crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Brother MFC-240Ccrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Brother MFC-240C Teardown, Brother MFC-240C Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown, Brother MFC-240C Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown, Brother MFC-240C Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Completely lift up scanner portion of printer and detach visible USB chord.
  2. Brother MFC-240C Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use flat head screwdriver to pry tabbed panel off.
  3. Brother MFC-240C Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift up ribbon cable and pull it through holder then remove ribbon cable from its track.
  4. Brother MFC-240C Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a flat head screwdriver, remove the 2nd tabbed panel.
  5. Brother MFC-240C Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4 plugs and unscrew ground-wire then place the plugs to the side.
  6. Brother MFC-240C Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your screwdriver press down on the tab as shown. This allows the hinge to be removed from the printing body as seen in photo.
  7. Brother MFC-240C Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Extend scanner assembly completely to remove scanner portion.
  8. Brother MFC-240C Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the scanner assembly, place it on its head. Remove the hinge and 4 screws from the lower scanner portion using Philips-head screwdriver.
  9. Brother MFC-240C Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place on opposite face, and gently pry upper and lower scanner portions apart. Remove the 4 plugs from the lower scanner portion.
  10. Brother MFC-240C Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove image sensor, detach the wire strip and pull it out. Remove the two springs that are under the image sensor after its removal.
  11. Brother MFC-240C Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the belt, first place the image sensor to the side then press down on the gear base to loosen belt and remove from the gear.
  12. Brother MFC-240C Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3 highlighted screws. For the gear driven by the motor, press the tab in highlighted gear to remove set gear. For the gear that was attached to belt, remove C-clip to remove gear then pull the last gear off.
  13. Brother MFC-240C Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the removing gears, lift up on the retained end of metal rod and pull out the other side.
  14. Brother MFC-240C Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother MFC-240C Teardown: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the rod has been removed, remove the metal plate in which the gears were sitting then take out the motor.
Andrew Adcock
crwdns2935283:011/10/16crwdne2935283:0
131 crwdns2915208:0crwdne2915208:0
This is only the scanner part? where is the printer part for teardown?
rene moret - crwdns2934203:0crwdne2934203:0
excellent guide, i like to know how to clean the head assembly and the the little hose that guides the ink to the head
alex jaimes - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,215
