for this teardown you will need a loaf of bread which you can get at pretty much any store but be absolutely sure it is not pre sliced because then this guide does not apply
with your utility Scissors carefully open the packaging and take out the loaf
Would it be helpful to let users know that pre-sliced bread could cause anomalous conditions when using this teardown procedure? I think there could be confusion if users encounter already formed slices after the bread is removed from the wrapper, and they are preparing to perform this step.
it is optional but adding butter to the bread will make it taste better
Option de l'option : optez pour du beurre 1/2 sel (pour les membres de la communauté catholique sachez que le beurre de missel n'existe pas)
once the bread is torn down it cannot be repaired
crwdns2947412:023crwdne2947412:0
Your guide is so helpful , long before my life was a completely mess because I couldn't even find even a single way to teardown a bread but after see your guide I am finally able to . Your help really saved my life , im really appreciated
I’m glad I could help
LucWag1 -
this guide genuinely changed my life, thank you
glad someone here as a good sense of humor lol
Thank you very much
LucWag1 -
I think my bread came in a different form factor. Does this guide still apply?
What kind of form factor
LucWag1 -
The guide has been updated as to clear up any confusion on what form factor of bread to get
Confusing instructions, couldn't slice my bread. 0/10 would not recommend.
thank you so much
As an owner of bread, this teardown was very helpful in repairing my bread after spilling some water on it. Props to you, man.
You can repair stale bread with a sprinkle of water and preheat it in an oven before disassembly.
If only for want of a bread knife.....
It is an honour to get a reply from Albert Einstein
LucWag1 -
Do you have a teardown for gluten free bread?
Thank you! I've been looking for a teardown on this for so long!
Who knew bread could be so complicated yet simple...
my bread broke 😢😢
take it to any bread repair center in your area
LucWag1 -
谢谢你我第一次知道面包还能这么吃以前我都是直接抱着啃的😭😭😭
Pro Tip: Most bread packaging features a service port secured by a standard bread-clip. Carefully remove the plastic clip to access the loaf without having to damage the packaging. Some models may feature a twist-tie instead of a bread-clip which can be reused to manage those cables you jammed into the back of your computer.
Sam Richeson - crwdns2934203:0crwdne2934203:0
