crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0breadcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
    • with your utility Scissors carefully open the packaging and take out the loaf
    Pro Tip: Most bread packaging features a service port secured by a standard bread-clip. Carefully remove the plastic clip to access the loaf without having to damage the packaging. Some models may feature a twist-tie instead of a bread-clip which can be reused to manage those cables you jammed into the back of your computer.
    Sam Richeson - crwdns2934203:0crwdne2934203:0
    • take your bread knife and slice two pieces of bread off of the loaf
    Would it be helpful to let users know that pre-sliced bread could cause anomalous conditions when using this teardown procedure? I think there could be confusion if users encounter already formed slices after the bread is removed from the wrapper, and they are preparing to perform this step.
    Bill Gilbert - crwdns2934203:0crwdne2934203:0
    • it is optional but adding butter to the bread will make it taste better
    Option de l'option : optez pour du beurre 1/2 sel (pour les membres de la communauté catholique sachez que le beurre de missel n'existe pas)
    Quentin Lacomere - crwdns2934203:0crwdne2934203:0
    • once the bread is torn down it cannot be repaired
    what about the bread repair that you made
    liam - crwdns2934203:0crwdne2934203:0
LucWag1
crwdns2935283:009/28/22crwdne2935283:0
477 crwdns2915208:0crwdne2915208:0
crwdns2947412:023crwdne2947412:0
thank u for the guide was very helpful
Rio - crwdns2934203:0crwdne2934203:0
Be careful it is not repairable after a tear down
LucWag1 -
Could have told me before hand? Now its broken 😭
NR26 -
Your guide is so helpful , long before my life was a completely mess because I couldn't even find even a single way to teardown a bread but after see your guide I am finally able to . Your help really saved my life , im really appreciated
thành thành - crwdns2934203:0crwdne2934203:0
I’m glad I could help
LucWag1 -
this guide genuinely changed my life, thank you
Josh Walton - crwdns2934203:0crwdne2934203:0
glad someone here as a good sense of humor lol
Britteny X. Wilson - crwdns2934203:0crwdne2934203:0
Thank you very much
LucWag1 -
I think my bread came in a different form factor. Does this guide still apply?
Colin - crwdns2934203:0crwdne2934203:0
What kind of form factor
LucWag1 -
The guide has been updated as to clear up any confusion on what form factor of bread to get
LucWag1 - crwdns2934203:0crwdne2934203:0
Confusing instructions, couldn't slice my bread. 0/10 would not recommend.
ravensuzuki - crwdns2934203:0crwdne2934203:0
As an owner of bread, this teardown was very helpful in repairing my bread after spilling some water on it. Props to you, man.
MrHoot2000 - crwdns2934203:0crwdne2934203:0
You can repair stale bread with a sprinkle of water and preheat it in an oven before disassembly.
teteabcmail - crwdns2934203:0crwdne2934203:0
If only for want of a bread knife.....
Albert Einstein - crwdns2934203:0crwdne2934203:0
It is an honour to get a reply from Albert Einstein
LucWag1 -
Do you have a teardown for gluten free bread?
Elizabeth - crwdns2934203:0crwdne2934203:0
Thank you! I've been looking for a teardown on this for so long!
techtalk11 - crwdns2934203:0crwdne2934203:0
Who knew bread could be so complicated yet simple...
nlr_fairygirl - crwdns2934203:0crwdne2934203:0
take it to any bread repair center in your area
LucWag1 -
谢谢你我第一次知道面包还能这么吃以前我都是直接抱着啃的😭😭😭
Quartz Gran Turismo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 5,118
