crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Blackview BV9200crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Blackview BV9200: Teardown, Heating the LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by heating the LCD. I use a heating pad set to 100 Celsius, and let it heat for 3-5 minutes.
    • If you don't have such a tool, you should be able to use a heat gun. Just heat the edges of the screen.
    • I would not recommend trying to get the screen off without heating the glue.
    • Consider using a more appropriate tool than a part of a box cutter blade to initially separate the LCD from the frame. (I would've tried using iFixit's Jimmy, but I haven't got it yet)
    • Be very careful if you use a part of box cutter blade. You could easily tear the LCD's cables or scratch the underside.
    • Be careful not to separate the LCD and touch panel. When removing the glue with a plastic card, either go underneath the LCD as well or only on the edges of the touch panel.
    • The video is sped up to fit within the 30 second limit. Do it slower and more carefully.
  2. Blackview BV9200: Teardown, LCD's connector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Teardown, LCD's connector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Teardown, LCD's connector: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the screw, remove the tab, unplug the LCD and pull it off.
    • I use tweezers to get the little tab that covers the connector out.
  3. Blackview BV9200: Teardown, Screeeeeeeews.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackview BV9200: Teardown, Screeeeeeeews.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Many screws.
    • Ones circled in red are all the same size, and ones circled in yellow are the same size as the one which held the tab that covered the LCD connector.
    • After you remove the screws, get leverage on the bottom. You will see a small indent where you can squeeze a tool in.
  4. Blackview BV9200: Teardown, Removing the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Teardown, Removing the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Teardown, Removing the battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cover.
    • Remove the cable. Connectors are pointed at by arrows.
    • Disconnect and remove the battery.
    • The battery is not glued or screwed in. Simply grab a hold of it and lightly pull it out.
  5. Blackview BV9200: Teardown, Cat: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Meow.
DegenFixer
crwdns2935283:009/18/24crwdne2935283:0
4,941 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 130
crwdns2942667:0crwdne2942667:0 1,291
