crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Belkin WeMo Switchcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Belkin WeMo Switch Teardown, Belkin WeMo Switch Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Belkin WeMo Switch Teardown, Belkin WeMo Switch Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Model: F7C027
    • FCC ID: K7SF7C027
    • Input: 120 V, 15 A, 60 Hz
    • Output: 120V, 15 A, 60 Hz
  2. Belkin WeMo Switch Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Belkin WeMo Switch Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 11.9 mm triangle screws securing the two halves of the case together.
    • The upper two screws are hidden underneath the label, so you'll need to cut away the sticker directly above the screws.
  3. Belkin WeMo Switch Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Belkin WeMo Switch Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pry the back case off.
  4. Belkin WeMo Switch Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 9.9 mm Phillips #1 screws securing the power board to the device.
  5. Belkin WeMo Switch Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to disconnect the power plug from the motherboard.
  6. Belkin WeMo Switch Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Belkin WeMo Switch Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power board from the device.
  7. Belkin WeMo Switch Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Belkin WeMo Switch Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Belkin WeMo Switch Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of spudger to gently pry the retaining flaps away from the motherboard.
    • The motherboard should now come free.
  8. Belkin WeMo Switch Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Belkin WeMo Switch Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Components on the motherboard:
    • Ralink RT5350 Wi-Fi SoC
    • Winbond W9825G6JH-6 256 Mb 166 MHz SDRAM
    • Macronix MX25L12835EMI-10G 128 Mb NOR Flash Memory
    • Momentary push button switch for factory reset
    • Momentary push button switch for power switch
  9. Belkin WeMo Switch Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Belkin WeMo Switch Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Components on the power board:
    • Hongfa HF3FA 10 A Relay
    • Power Integrations LNK606DG 5.5 W AC/DC Converter
    • TAICON 6.8 µF Capacitor (x2)
    • FOAI 680 µF Capacitor (x2)
    • JOYIN JVR10N471K 385 V 70 J Varistor
    • Chipsen EPC13 50 W Transformer
    • PANJIT International TB8S 800 V 30 A Bridge Rectifier Diode
  10. Belkin WeMo Switch Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Final layout.
Geoff Wacker
crwdns2935283:009/30/13crwdne2935283:0
91.240 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
I notice that’s a 240V 10amp relay they’ve used. Do you think there is any electrical difference (aside from the plug pattern) between the US 110V version and the EU/Australian 220V one?
Greg Bromage - crwdns2934203:0crwdne2934203:0
Thank you, that was a big help! The exterior on off button had come loose and was rattling around inside and I was able to repair it thanks to your tear down guide.
L Threet - crwdns2934203:0crwdne2934203:0
A T-7 torx screwdriver works well if you don't have the 2mm triangle
olaf - crwdns2934203:0crwdne2934203:0
Thanks, also here 2 of them after little use: The exterior on off button had come loose and was rattling around inside. Very poor quality now I have opened them. Guess need to try and glue them back on.
Helmuth van Es - crwdns2934203:0crwdne2934203:0
The relay in the UK version is an HF7520-005-HSTP (13 amps). Mine has stopped switching so I'm going to try replacing the relay.
Ian - crwdns2934203:0crwdne2934203:0
What is the reference of the "Momentary push button switch for power" for replace mine which is not there enymore... (micro-switch 4 pattes generaly ). and how to solder it to fix it ?
remarks: Power PCB model seems different for UE format but seems same for Mother Board
Albert - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 10,114
