crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Apple USB Power Adaptercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Apple USB Power Adapter Teardown, Separating the input panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple USB Power Adapter Teardown, Separating the input panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple USB Power Adapter Teardown, Separating the input panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a hammer and a small chisel to carefully force the input panel open
    • Clamping the device helps prop the input panel open but, do not pull the panel away from the device forcefully, as there are small wires connected to the device components.
    • Be careful not to force the chisel into the device as you could damage internal components.
  2. Apple USB Power Adapter Teardown, Removing plastic casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple USB Power Adapter Teardown, Removing plastic casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use dyke and pliers to cut outside casing to pry open the shell and remove the circuitry.
    • Recommend using hand saw to cut around the plastic.
    • Be careful not to cut forcefully as to prevent the internal components from getting damaged.
  3. Apple USB Power Adapter Teardown, Isolating internal components: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple USB Power Adapter Teardown, Isolating internal components: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple USB Power Adapter Teardown, Isolating internal components: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Isolate the internal electrical components from the casing
    • Recommend unsoldering the wires from the input panel.
    • For help desoldering connections, follow this useful guide on How To Solder and Desolder Connections.
    • Use caution when soldering. The heated tip may cause damage to the board, the components, or burn you.
  4. Apple USB Power Adapter Teardown, Accessing individual components: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple USB Power Adapter Teardown, Accessing individual components: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple USB Power Adapter Teardown, Accessing individual components: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unsolder components that connect to the bottom and top circuit boards.
    • Detach the top and bottom circuit boards from the plastic separator.
  5. Apple USB Power Adapter Teardown, Exploration: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple USB Power Adapter Teardown, Exploration: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Observe that once the circuit boards are separated individual components can be accessed.
Juan Gonzalez
crwdns2935283:001/24/19crwdne2935283:0
422 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 62
crwdns2936753:030crwdne2936753:0 238
crwdns2942667:0crwdne2942667:0 19,845
