crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Apple Disk II Floppy Disk Subsystemcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, The case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The outside of the drive.
  2. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Outside screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the drive over and remove the 4 Phillips screws underneath.
  3. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove the outer case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide it towards the cable at back.
  4. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Disconnect cables: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Disconnect cables: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull away from the board, not up
  5. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Disconnect cables: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Disconnect cables: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  6. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Disconnect cables: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Disconnect cables: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Disconnect cables: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First. remove the C retaining clip by gently pushing the sides away from the connector with your thumbs, then pull the cable away from the board, not up
  7. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Circuit board removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Circuit board removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Circuit board removal: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2 Phillips screws
    • Next, gently remove the board from the drive, minding the cable running beneath
  8. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, View of the remaining part and removed board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, View of the remaining part and removed board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert wisdom here.
  9. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Sensor removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Sensor removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Sensor removal: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 2 Phillips screws holding in the sensor pictured
  10. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Cable removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Cable removal: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the grey cable from its retaining clip
  11. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove screws: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove screws: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • All screws pictured
  12. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove silver tray: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • As pictured, remove tray once screws are gone
  13. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Tray and other components: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In addition to tray, lift out other components as pictured
  14. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remaining components: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  15. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove screws: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove screws: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 8 total, from sides and bottom
  16. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove bottom of case: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  17. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Remove screws: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • As pictured, then remove all freed components
  18. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Motor Removal: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Motor Removal: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect cables from black connector so motor and other components can be removed from chassis
  19. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Side rail removal: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Side rail removal: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove side rails by pulling up gently. Each rail has two plastic poles that sit in the body. In this attempt, each rail lost a pole that snapped off. Poles seemed to be glued down
  20. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, LED removal: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, LED removal: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Because the side screws were previously removed, the black front of the drive can come off. Our drive's LED was tested and worked, but was faint. Feel free to test yours first. If working, skip the next step
    • Our LED was removed from the front case by removing the pictured ring with the help of a flathead screwdriver. Take your time so the front of the case isn't damaged and nothing besides the ring comes off
  21. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Final removals: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use pliers to remove the remaining components (see previous step)
  22. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Adding new components: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Adding new components: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the case stripped and a new LED purchased, the fun begins!
    • The only major changes to the case are outlined in rectangles. The metal chassis was milled down to match the height of the bottom of the disk entry area on the black front plate. This lined up well with our Apple SuperDrive (pulled from a MacBook Pro)
    • The wood block was added for support underneath the SuperDrive
    • The rails fit nicely around the SuperDrive when re-installed
    • A new LED was purchased and soldered to the LED connector from a 2.5" USB to SATA board, and then inserted snugly into the front of the case (may not be necessary if your LED lights up well)
  23. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Detail shots: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Detail shots: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Detail shots: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With LED cabled routed, and 2.5" hard drive placed in cavity underneath
  24. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Further case modification: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Dremeled into the back plate for USB cables to route through
  25. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Installing SuperDrive: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Installing SuperDrive: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Installing SuperDrive: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Picture 1: optical drive installed into body
    • Picture 2: SATA to USB cable for optical drive (plug and play on macOS. A right angle cable was purchased but a straight cable would be preferable due to the amount of space at the back, as pictured)
    • Picture 3: hole to thread SATA to USB cable through for 2.5" hard drive
  26. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, New front: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The original 'latch' slides out easily without the original components, so it was left out
  27. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Cables: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Cables: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Run out of case to 4-port USB adaptor (possible to install inside case if a hole could be cut out)
  28. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, New LED: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flashes on SATA data read from hard drive
  29. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, SuperDrive: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the drive connected to a Mac over USB (hub is enough to power both OD and SATA drive over one cable) we can insert and eject DVDs with ease!
  30. Apple Disk II Floppy Disk Subsystem Teardown and Optical Drive Conversion, Final shot: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To re-assemble, replace all body Phillips screws
    • Enjoy your vintage look with up to date tech!
Jon
crwdns2935283:007/16/14crwdne2935283:0
633 crwdns2915208:0crwdne2915208:0
crwdns2944067:010crwdne2944067:0
Thanks! Hope others try it.
Jon -
OH MY GOSH THIS IS SO AMAZINNNNGGG!!! Thanks for making the guide! Now I just need to get an Apple Disk II haha, amazing.
Moses Buckwalter - crwdns2934203:0crwdne2934203:0
Acquired! Can’t wait!
Moses Buckwalter -
I don’t have that device yet , where can I buy it? , and does it support USB 2.0? , and how does it get electricity for the engine?
Insert PlayZ - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,641
