crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Apple 5W USB Power Adapter (Folding Pins - UK plug)crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown, Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown, Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Released with the Apple Watch in the UK / HK, the new folding plug has pins that fold completely flush for travel.
    • Matches the older style plug with a 5W / 1A specification.
    • AC 100 - 240V input.
    • This product uses and can store high voltage electricity - it is dangerous and could potentially kill you.
  2. Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Becoming more common on mains chargers, most of the design is fastened together during the moulding process. There is only a single screw (Torx T9 M2.5 x 2.75mm) in the entire product.
    • You could possibly pry this open, but you would likely make a big mess. Instead this has been cut in two using a fine bladed coping saw.
    • This was cut 1mm behind the USB port entrance.
    • Inside we can see the design has been split into two halves.
    • All of the electronics are on a single PCB on the left.
    • All of the mechanism and high voltage contacts are on the right hidden under plastic hood.
  3. Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A break down of the top side of the PCB:
    • Rubycon 4.7µF 400V electrolytic capacitor 400AX4.7M8X9
    • Fairchild bridge rectifier MB10S
    • Everlight optoisolator EL3H7-G
    • Transformer markings 157-00003 / HIG J 1503
    • There's copper shielding to meet EMC requirements on the rear of the housing.
  4. Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the reverse side:
    • Fairchild PWM Controller FAN301
    • Fairchild N-Channel MOSFET STD7NM64N
    • Recessed inductor markings T00405 SP451
    • KEMET Tantalum Polymer Capacitor T520M157M006ATE035
    • Diode SBR8U60P5
    • There's a blob of resin over R9 - a mistake?
    • FAN301 currently has an injunction against it due to patent infringement. Perhaps this doesn't affect European sales?
  5. Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Most of the mechanism is covered with a hood, fixed at points using thermoplastic staking during production.
    • The only way to remove the cover is to cut the tops off these.
  6. Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Finally we can see how the mechanism works!
    • The yellow tape is Polyimide high temperature film.
    • The cover is needed for the mechanism to work properly - the central black plastic piece will lift otherwise.
  7. Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple 5W USB Power Adapter (Folding Pins - UK plug) Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the side of the bottom section filed away, you can see the stackup of the PCB, mechanism and contacts exposed.
    • The Apple folding charger repairability Score: 1 out of 10 (10 is easiest to repair)
    • Almost everything is moulded together during manufacture, making it impossible to take apart without damage.
    • Trying to reassemble this and use it would not be safe!
Oliver
crwdns2935283:004/30/15crwdne2935283:0
253 crwdns2915208:0crwdne2915208:0
Fantastic, thanks for this great article.
James Campbell - crwdns2934203:0crwdne2934203:0
What are all the additional electronics on the PCB for? Why not just a plug?
Jean-Marc Moninski - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 107
crwdns2942667:0crwdne2942667:0 27,705
