crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Amazon Fire Stick 4kcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Amazon Fire Stick 4k Remote Teardown, Heat the remote to loosen the glue.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat it a lot if you are trying to maintain it in working order because it seems the glue on the clasps was very strong. I probably broke mine taking it apart (but it didn't work anyway so I don't know).
  2. Amazon Fire Stick 4k Remote Teardown, Pry it apart.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire Stick 4k Remote Teardown, Pry it apart.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • It takes A LOT of force to pry this apart. I'm not sure it's possible without breaking the inside.
  3. Amazon Fire Stick 4k Remote Teardown, Remove the seven motherboard screws.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Very easy to remove with the #0 phillips screwdriver.
  4. Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screws are removed, all the pieces come out easily.
    How do you put it back together?
    Sbip weksa - crwdns2934203:0crwdne2934203:0
    I didn't put it back together because mine had too much leaked battery damage. I hoped by writing this tear-down it would help the next person take theirs apart and damage it as little as possible and be able to reassemble it if there wasn't damage. The best answer to your question I can give is: reassembly is the reverse of the tear-down.
    Nathan Ruffing -
Nathan Ruffing
crwdns2935283:005/24/21crwdne2935283:0
692 crwdns2915208:0crwdne2915208:0
Thanks for the teardown, new firestorm 4k has a couple of screws under the round wheel, but you can pop that off and the remove.
. I used a pair of pliers to just rip off the mic, it is surface mounted and comes away with the pads and remote still works. Small amount of glue on the inside.
Scott - crwdns2934203:0crwdne2934203:0
Took my firestick apart and this is what I found it is nothin like my spare one I have,why does it look like it does?is it possibly being used for something else???I can also send pics
Glenn McCulloch - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 165
crwdns2942667:0crwdne2942667:0 5,798
