crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Acer Optical Mousecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Acer Optical Mouse Teardown, Gather Items: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay out your mouse and gather your tools.
  2. Acer Optical Mouse Teardown, Remove sticker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use metal spudger to lift sticker
    The wireless version has two (2) more screws under the other two (2) small circular pads.
    Terry Ess - crwdns2934203:0crwdne2934203:0
  3. Acer Optical Mouse Teardown, Unscrew: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a phillips #0, unscrew the screws
  4. Acer Optical Mouse Teardown, Lifting the lid: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Applying some force lift the mouse top up and backward at the same time to disconnect it
  5. Acer Optical Mouse Teardown, Remove scroll wheel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once inside pull on the scroll wheel to remove it from the board
  6. Acer Optical Mouse Teardown, Remove motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the cable and the board should come out
    The wireless version has yet another small Philips head screw holding the main board to the base.
  7. Acer Optical Mouse Teardown, Remove plastic: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then pull out the plastic at the bottom
    In the wireless version there is also a slider under the main board that engages with the battery (AA size) isolation switch.
  8. Acer Optical Mouse Teardown, All done: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All done just follow guide in reverse to reassemble
Oduelca
crwdns2935283:005/15/21crwdne2935283:0
187 crwdns2915208:0crwdne2915208:0
The wireless version of this mouse has 2 extra screws under the other two small pads and arranged differently because of the battery compartment intrusion into available space. There was also a small screw retaining the circuit board.
crwdns2936753:030crwdne2936753:0 137
crwdns2942667:0crwdne2942667:0 4,693
