crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Acer Nitro 5 AN517-52crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Acer Nitro 5 AN517-52 Basic Teardown, Remove the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 12 Philips screws on the back. Slip fingernails in cracks and snap open the back all around. Be gentle and it will come off.
  2. Acer Nitro 5 AN517-52 Basic Teardown, Replace battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 Philips screws holding the battery. Gently twist counter-clockwise to release the corners. Unplug the connector straight, without twisting.
  3. Acer Nitro 5 AN517-52 Basic Teardown, Clean fans: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fans are great at removing dust from the room then do not work well. Look at the right fan in the picture - dusty. Some dust can be removed with tweezers. Other dust can be blown off with a can of compressed air but put a finger on the fan to prevent it from spinning. Note that replacing the fans is not simple due to heatsink complications.
  4. Acer Nitro 5 AN517-52 Basic Teardown, SSD/HDD replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replacement of the SSD/HDD is suprisingly simple. Remove the 4 Philips screws, slide the drive straight to the side.
  5. Acer Nitro 5 AN517-52 Basic Teardown, Button cell replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The small button cell is in black heatshrink, held in with one connector only. Unplug it. If you know what you are doing, solder in a new one otherwise replace the assembly.
  6. Acer Nitro 5 AN517-52 Basic Teardown, Replace speakers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • I you crank up the toons [sic] too much and break a speaker, they are simple to replace. Unscrew them and unplug the connectors.
    • Keyboard replacement is quite involved and susceptible to fatal damage to the laptop due to connector damage. It involves removing the battery, fans/heatsink assembly, I/O boards, shields, mother board and cutting plastic standoffs, then plastic welding them back with the new kbd. This procedure will not be covered here.
AlStu
crwdns2935283:011/20/22crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
Quick question for you, are those two fans identical or are they different? Looking to replace mine and found a single one on Amazon and I want to know if it’ll work on both sides if I buy two.
Skid-Wheel Playz - crwdns2934203:0crwdne2934203:0
Hello Where can I buy a new motherboard ?
Roberto Nascimento - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 358
crwdns2942667:0crwdne2942667:0 11,625
