crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Acer Liquid E1crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Acer Liquid E1 Teardown, Acer Liquid E1 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic back and the exposed battery.
    • Do not forget to remove sim- and SD-cards
    • Use a torx t5 to unscrew all screws. This will be the first and last time you'll use a screwdriver with this device.
  2. Acer Liquid E1 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool or spudger
    • Pry around the side to release the backframe from the middleframe
    • Be careful as the frame is quite fragile
  3. Acer Liquid E1 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To free the main board, remove the connector and antenna-cable
    • Use a plastic spudger
    • Be careful not to chip components
  4. Acer Liquid E1 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilting the main board will reveal this connection
    • Use a plastic spudger to open the lock
    • Carefully pull the flex cable out of it
    • Don't put alot of stress on it
  5. Acer Liquid E1 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the bottom, use a pair of tweezers to remove the yellow tape from the connector
    • Use a plastic spudger to unlock
    • Pull the flexcable out carefully
  6. Acer Liquid E1 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, use a platic spudger to remove the flex cable from its connection
  7. Acer Liquid E1 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to remove the bottom-plate from the frame.
    • Be careful when using metal tools (like I did)
    • Make sure the antenna cable isn't attached to anything except it's socket
  8. Acer Liquid E1 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Let the remaining heat at 95°C for about 3-5 minutes to soften the adhesive
    • Use an opening tool to pry at the top, between your digitizer and the middleframe
    • Open it from the top, your digitizer-flex runs at the bottom
    • Be careful when using a heat-gun. Heat-guns don't distribute heat evenly and LCD-burns may occur
  9. Acer Liquid E1 Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Liquid E1 Teardown: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the LCD, remove the sticker on the back of the midframe. It conseals the LCD-flex
    • Be careful when removing the sticker. It's glued tightly and too much stress will tear the LCD-flex
    • Remove the LCD by pulling the whole cable through the midframe.
  10. Acer Liquid E1 Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All done
    • I hope you enjoyed it as much as I did
Maxim
crwdns2935283:004/30/14crwdne2935283:0
2 297 crwdns2915208:0crwdne2915208:0
iFixers Belgium crwdns2935289:0iFixers Belgiumcrwdne2935289:0
Business
Great Manual.. it work fine! thanks,,
JoeTech - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 7,589
