PDF manual here: AGPTEK A02 Manual
Remove the microSD card, if present. You can use a flat side of a spudger
With a Pick, insert the tool and split the two parts that make the shell of the mp3 player
Use Jimmy, if the pick is too flexible for you
Remove 3 screws with a #00 Philips screwdriver
Remove the switch with the shape of a spudger
That's all. The screen is welded and coated with glue.
command bottons
usb port
the switch
SD card holder
Full IC Identification:
Predicted Block Diagram is on the 2nd image.
where is the radio chip and recording module?
My headphone jack only works on one channel. I can only get both channels to work if I press very hard on the headphone plug (I've tried this with two separate headphones - the issue is definitely within the player and not with the headphones). Do I have any recourse?
