Bring back the click
joe -
MacBook Air 13" Mid 2012
MacBook Air 13" Mid 2012 Trackpad Replacement
crwdns2931287:050crwdne2931287:0 - crwdns2931291:02crwdne2931291:0
Moderate
Trackpad stopped clicking got spongy when pushing down unlike before. Started to get stuck when dragging things.
Man, those are some tiny screws, glad I don't have Andre the Giant hands. Took me a few tries to get the positioning of the set screw just right but no problems, no extra parts/screws, and great iFixit step by step was spot on.
The set screw needs to be set at a fairly precise point and should not be tightened. Once the trackpad is screwed in with the two ribbon cables are properly reattached and the set screw is in place but not deeply set, put the battery unit back on top but do not screw down. Flip over holding the battery in position with your hand especially at the bottom center where the trackpad is, lift the screen up and try the trackpad full click. There should not be any downward play before the click, lightly tap the trackpad at bottom center and if you feel any play flip unit back over and tighten the set screw a half turn and then retry. Don't be impatient, just keep trying until the trackpad feels right. The bottom/front edge of the trackpad should be ever so slightly below the rim of the chassis. The trackpad should definitely not sit above this rim and it should not sit too far below either. If you have a friends macbook handy, test the edges with your finger to get a sense of how yours should feel when put back together. It's almost impossible to get the set screw just right without putting the battery back first so go with this trial/error method until you get the feel and positioning just right. If you feel any resistance or friction in the up/down motion of the front/bottom edge of the trackpad, you may need to loose or remove the six screws again and just reset to be sure it's in exact center free-moving position. Good luck! Sorry, no photos, will take some next time.
crwdns2886500:0Mako Driver Kit - 64 Precision Bitscrwdne2886500:0
$39.95
crwdns2886500:0MacBook Air 13" (Mid 2011) Trackpadcrwdne2886500:0
$89.99
