Hoover 5000PH vacuum cleaner dismantle
Neil Frazer -
Overfull Bag burst, filled vac motor with dust, wanted to clean out
Dismantling stage 1, 1 different screw out of 4 under the lid, 2 other hidden screws frustrating.
When disconnecting power cord from PCB, the spade terminals came off, had to solder back on.
Otherwise completed job fine.
There are 6 screws to pop the top off. 4 are under the lid, but one if these is unique. It is a T20H
There are 2 more screws hidden. One is accessible after removing the retracting power cord plug receptacle from its recess. The other is under the power switch button on top, that you have to pry off.
TEXTO TRADUCIDO A ESPAÑOL:
Mi Problema
Reventó la bolsa, llenó de polvo el motor de la aspiradora, quería limpiarla
Mi Solución
Desmontaje etapa 1, 1 tornillo diferente de 4 debajo de la tapa, otros 2 tornillos ocultos frustrantes.
Al desconectar el cable de alimentación de la PCB, los terminales de pala se desprendieron, tuve que volver a soldarlos.
Por lo demás, todo bien.
Mi Consejo
Hay 6 tornillos para quitar la tapa. 4 están debajo de la tapa, pero uno de ellos es único. Es un T20H
Hay 2 tornillos más ocultos. Uno es accesible después de quitar el receptáculo del enchufe del cable de alimentación retráctil de su hueco. El otro está debajo del botón del interruptor de encendido en la parte superior, que tienes que hacer palanca.
Carlos López (España - Spain) - crwdns2934203:0crwdne2934203:0
Did you use a service manual in order to repair this item? Recently I had another type also from the brand Hoover. In case you are looking for one, you can visit https://www.trading-247.com. They have over one 1.000.000 manuals, schematics instuctions available.It was digital delivered within 5 minutes. First I tried to repair it without it but I was affraid that my modus operandi was not good ;-)
Gijs - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 68
