MacBook SSD Upgrade
Eric Outen -
MacBook Core Duo
MacBook Core Duo Hard Drive Replacement
crwdns2931287:010crwdne2931287:0
Easy
This wasn't necessarily a fix, but I wanted to speed up my 2007 MacBook because it still works great for Photoshop and Illustrator. I was also holding off upgrading the OS to Lion until I could get an SSD so the installation process would be less tedious. I purchased a Crucial 240GB SSD from Amazon which is double the storage of the 120GB SATA that came with the MacBook.
The hard drive swap couldn't have been any easier. I might have hit a snag if I didn't already have a screw driver set with Torx screw bits, but the screws stick out far enough that someone could unscrew them with a small pair of pliers I suppose. I don't think it took longer than ten minutes to swap the hard drives and get everything back together.
I would highly recommend reading through the guide carefully and making sure you have a set of Torx screwdrivers available. Otherwise, if you're comfortable with removing the battery and undoing a couple screws I don't think you should run into any problems.
crwdns2886500:0TR8 Torx Security Screwdrivercrwdne2886500:0
$5.99
crwdns2942667:0crwdne2942667:0 763
