Hard drive cable fixed it!
Peter Hillman -
MacBook Pro 13" Unibody Mid 2012
MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement
10 - 25 crwdns2931279:0crwdne2931279:0
Easy
I bought a used MacBook Pro 13 Mid-2012 and it would only recognize a 250GB hard drive or smaller. The seller said the original drive went bad and they replaced it with a 250GB drive. I bought a 500GB SSD and discovered the problem when the MBP failed to boot from the drive. It would not even recognize a 750GB drive. Both drives worked fine in a USB enclosure. The Apple Store hinted it was the hard drive cable, but they would not repair it due to the original drive being replaced with a third-party drive. I wanted them to test the logic board to see if the SATA chip was bad.
The installation was simple. I had the new cable installed in about 20 minutes.
If you think your hard drive went bad in a MacBook Pro, test it in an external enclosure first. The hard drive might not be the problem. It might be the hard drive cable.
crwdns2886500:0MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cablecrwdne2886500:0
$34.99
crwdns2942667:0crwdne2942667:0 193
