PC2-5300 4 GB RAM Chip
  • PC2-5300 4 GB RAM Chip
$59.99
$59.99
crwdns2860691:0crwdne2860691:0
crwdns2860792:0crwdne2860792:0
Adding RAM to your computer can provide a significant performance boost.
Works only in Macbooks and MacBook Pros with Santa Rosa or Penryn chip sets. This chip will not work in computers with Core Duo or Core 2 Duo (non-Santa Rosa or Penryn) processors. If you're not sure which model computer you have, identify your Mac. The Santa Rosa and Penryn Core 2 Duo MacBooks and MacBook Pros can address up to 6 GB of RAM using this chip along with a 2 GB RAM chip.
You may receive a PC2-6400 RAM chip instead. These chips are fully backwards compatible and will function identically to the PC2-5300 chips.
crwdns2860690:0crwdne2860690:0
  • 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo MacBooks (Excludes MacBook Unibody)
  • 2.16, 2.2, 2.33, 2.4, 2.5 or 2.6 GHz (Models A1226/A1260) 15" MacBook Pros
  • 2.33, 2.4, 2.5, or 2.6 GHz (Models A1229/A1261) 17" MacBook Pros
  • 2 or 2.16 GHz 17" Intel iMacs
  • 2.16, 2.33, 2 (EMC 2133) or 2.4 (EMC 2133) GHz 20" Intel iMacs
  • 2.16, 2.33, 2.4 or 2.8 (EMC 2134) GHz 24" Intel iMacs
  • 1.83 or 2 GHz Core 2 Duo (Model A1176) Mac minis (3 GB maximum)
crwdns2881795:0crwdne2881795:0
RAM Type:
200 pin, DDR-2, 667 MHz
Height:
1" (Low Profile)
iMac Intel 17"
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
Mac mini Model A1176
1.83 GHz (Core 2 Duo, Mid 2007)
2 GHz (Core 2 Duo)
MacBook Core 2 Duo
A1181 (EMC 2121) 1.83 GHz
A1181 (EMC 2121) 2 GHz (Late 2006)
A1181 (EMC 2121) 2 GHz (Mid 2007)
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2139) 2.16 GHz
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
MacBook Pro 15" Core 2 Duo Models A1226 & A1260
A1226 (EMC 2136) 2.2 GHz (Santa Rosa)
A1226 (EMC 2136) 2.4 GHz (Santa Rosa)
A1226 (EMC 2136) 2.6 GHz (Santa Rosa)
A1260 (EMC 2198) 2.4 GHz (Penryn)
A1260 (EMC 2198) 2.5 GHz (Penryn)
A1260 (EMC 2198) 2.6 GHz (Penryn)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
A1229 (EMC 2137) 2.4 GHz (Santa Rosa)
A1229 (EMC 2137) 2.6 GHz (Santa Rosa)
A1261 (EMC 2199) 2.5 GHz (Penryn)
A1261 (EMC 2199) 2.6 GHz (Penryn)
crwdns2887036:06crwdne2887036:0
crwdns2881997:0crwdne2881997:0
I am trying to avoid spending a bunch of money on a Mac Pro. My MBP came with 4 GB ram, 10 years ago. I recently heard somewhere it was possible to increase it to 6 MB. I talked with a tech at ifixit.com and found out it was in fact possible. Ordered the part on line (about $95 with shipping).
The pa . . .
I wanted to see if the rumors were true that I could run 6gb of ram in my iMac 7,1
It was very easy just popped the ram door, put the ram in and booted up to make sure the ram was being recognized and used before reinstalling the ram door
6gb of ram works in an iMac 7,1. Be gentile if it's your first . . .
I wanted to upgrade my Apple iMac from 2 to 8 GB to speed it up because I was experiencing a lot of swapping.
I ordered 2x PC2-5300 4 GB RAM chips on iFixit to replace the 2x 1 GB in my iMac.
At first it did not work, the iMac would not boot, and Ryan from iFixit advised that my computer could not ta . . .
My Macbook Pro was running real slow, so I upgraded from 2GB to 5GB.
It went real smooth. I just needed to take off the battery, three screws, pop off the old ram and insert the new one.
No, even a girl can do it ;)!
I had to upgrade the RAM in my 2007 Mac Book Pro 15" in order to install and run IOS Maverick smoothly. I was running on 2 gigs of ram and based on some web research I did, I had to upgrade my RAM to at least 4 gigs. I went to the Apple store to see if they provided this service and how much they we . . .
Well my MacBook Pro was getting slower and slower through the years and i was upset by this so i finally decided to boost the RAM. Exit the basic 2go and welcome the 6go!
Really simple and easy. That's it. My MBP is much more quicker and i enjoy use it again.
Here is a second life for my MBP and may . . .
The original 1 GB was just not cutting it on this old puppy... Also, OS 10.6.8 is as far as it would upgrade, leaving me out of the Cloud.
Everything went super smooth and easy!
I wish I had thought of doing it myself earlier!
Though the upgrade to I OS 10.7 is still on hold due to something str . . .
Upgrade vs. new
Piece of cake...very straight forward. Formatting hard drive and setting up OS X was the only process that took some time
Keep it up! Thanks
I had ruined the keyboard by trying to clean it with a dampened cloth and Windex. I found out later to use only distilled water, and a minimum of that on a cloth, wrung-out as much as possible.
Since I had to go in to replace the keyboard [from Amazon], I also decided to max out the RAM to 6GB, . . .
Slow performance in my MacBook 13'' Early 2009. Run out of disk space.
Smooth. Simple. Upgrading memory and Hard Drive are among the easiest task you can do in this MacBook model.
Before taking out the Hard Drive, I repaired permissions. I used the rubber case included in the kit to be able to use the . . .
crwdns2882080:0crwdne2882080:0
