MacBook Pro 15" (Model A1211) Left I/O Board
  • MacBook Pro 15" (Model A1211) Left I/O Board
  • 360°
360
$29.99
$29.99
crwdns2860691:0crwdne2860691:0
crwdns2860792:0crwdne2860792:0
Replace a damaged or corroded I/O board for your model A1211 MacBook Pro 15" and fix problems with charging, audio, and data connections.
  • Includes the MagSafe power, USB, and audio ports.
  • Includes slots for internal Airport wireless card and PC Card ExpressCards.
crwdns2860690:0crwdne2860690:0
  • MacBook Pro 15" A1211
crwdns2881795:0crwdne2881795:0
Part #:
922-7911, 820-2055-A
MacBook Pro 15" Core 2 Duo Model A1211
A1211 (EMC 2120) 2.16 GHz
A1211 (EMC 2120) 2.33 GHz
crwdns2881997:0crwdne2881997:0
Old Macbook Pro, no longer charging. I thought this laptop was consigned to the bin as the repair would have cost hundreds (at least that's what I thought!)
It went surprisingly well and with very little collateral damage to other systems
1) Make sure you've got lots of space
2) Make sure that space i . . .
Working on my 2006 MBP , computer suddenly shut down, no warning of low battery, nothing. I immediately plugged in the charger, and noticed that the mag. plug did not / would not change to the orange charging state. I then checked the battery, ¾ charged. I managed to get the MBP laptop running . . .
A friend of mine dropped her macbook pro while it was charging and the magnet jack broke. She took it to an apple store to see about repairs, but out of warranty she was quoted 500$+ to repair it. She has 4 kids and is a single mom she could not afford the repairs or a new laptop, since I have exp . . .
Went to plug in the magsafe adapter into the MBP and got a juicy static electric discharge at the connector. Battery would not charge even though it continued to work off the power it was supplying. Tried another battery and had the same problem. My fear was correct in assuming the Left i/o board wa . . .
IO Board broke because pB dropped on the magsafe plug ;; ripped the connecters of the IO Board & blew some circuit.
Part arrived before promised ship date; with the on-line guide replaced the board; reset PRAM and SMC and all is fine again. Very smooth dealing with Ifixit ... kudos' !!
no as difficult . . .
For years I've had a chronic problem with battery charging on a MacBook Pro. The laptop would indicate significant battery life remaining, yet discharge too rapidly and at some point abruptly crash as though all power was removed. Eventually, the battery would not charge at all and the laptop would . . .
My computer was not charging. The power cord would short out due to a bad connection at the Left I/O Board. The cause of the problem started years ago when my daughter decided to chew on the end of the power cord causing corrosion and subsequently shorting between the power cord and Left I/O Board c . . .
crwdns2882080:0crwdne2882080:0
