MacBook Pro 15" (Non-Unibody) Display Components
Grab a toolkit for your MacBook Pro 15" (Non-Unibody) model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
crwdns2887038:0MacBook Pro 15" (Non-Unibody)crwdne2887038:0
crwdns2889374:0MacBook Pro 15" (Non-Unibody)crwdne2889374:0
MacBook Pro 15" (Models A1150/A1211) Display Data Cable
A damaged display data cable can cause video defects
MacBook Pro 15" (Models A1226/A1260) Clutch Cover
Houses the hinges and airport antenna assembly.
MacBook Pro 15" (Model A1150) Inverter/iSight Cable
MacBook Pro 15" (Models A1226/A1260) Front Display Bezel
Replace a damaged bezel without the cost of a new LCD
MacBook Pro 15" (Models A1150/A1211) Display Inverter
A bad inverter board can cause a dead backlight
MacBook Pro 15" (Model A1150) Clutch Cover
MacBook Pro 15" (Model A1150) Antenna Cover
This antenna cover houses the airport antenna assembly compatible with the Model A1150 EMC 2101 15 inch MacBook Pro laptop. Part #922-7279.
MacBook Pro 15" (Models A1150/A1211) Rear Display Bezel
MacBook Pro 15" (Models A1211/A1226) Airport Antenna Cables
Replace the antenna cables and the assembly that rests inside the antenna cover compatible with the A1211 or A1226 model 15 inch MacBook Pro laptop.
MacBook Pro 15" (Models A1226/A1260) LED Driver Board
LED Driver Board controls the LED backlight.
crwdns2861003:0crwdne2861003:0
The MacBook Pro 15" replaced the Aluminum 15" and features Intel support and an integrated iSight camera.
All MacBook Pro 15" Non-Unibody models use PC2-5300 RAM. Two RAM slots means an easy memory upgrade! If storage is an issue, any 9.5mm SATA hard drive will expand your boundaries.
Heat has always been an issue for MacBook Pros. It's possible that a bad thermal sensor or fan will prevent the machine from booting.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Non-Unibody repair guides for step-by-step instructions on how to make the fix.
