MacBook Pro 15" (Non-Unibody) Case Components
Grab a toolkit for your MacBook Pro 15" (Non-Unibody) model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
crwdns2887038:0MacBook Pro 15" (Non-Unibody)crwdne2887038:0
crwdns2889374:0MacBook Pro 15" (Non-Unibody)crwdne2889374:0
MacBook Pro 15" (Model A1226) Lower Case
Replace a scratched-up lower case
MacBook Pro 15" (Model A1226) ExpressCard Cage
Covers ExpressCard slot on left I/O board
MacBook Pro 15" (Model A1260) Lower Case
MacBook Pro 15" (Model A1260) ExpressCard Cage
MacBook Pro 15" (Models A1226/A1260) Front Display Bezel
Replace a damaged bezel without the cost of a new LCD
MacBook Pro 15" (Model A1150) Upper Case
Replace an upper case assembly compatible with the model A1150 MacBook Pro 15 inch laptop. Includes palmrest area, trackpad, trackpad cable, and power button.
MacBook Pro 15" (Model A1150) Lower Case
Replace a scratched-up lower case for MacBook Pro 15" Core Duo
MacBook Pro 15" (Model A1150) Airport Card Bracket
Holds Airport wireless internal card in place
MacBook Pro 15" (Model A1211) Lower Case
MacBook Pro 15" (Model A1211) Upper Case
Replace an aluminum upper case and trackpad compatible with the Model A1211 15 inch MacBook Pro laptop. Part #922-7909.
crwdns2861003:0crwdne2861003:0
The MacBook Pro 15" replaced the Aluminum 15" and features Intel support and an integrated iSight camera.
All MacBook Pro 15" Non-Unibody models use PC2-5300 RAM. Two RAM slots means an easy memory upgrade! If storage is an issue, any 9.5mm SATA hard drive will expand your boundaries.
Heat has always been an issue for MacBook Pros. It's possible that a bad thermal sensor or fan will prevent the machine from booting.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Non-Unibody repair guides for step-by-step instructions on how to make the fix.
