MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
  • MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
  • 360°
360
209,99 $
209,99 $
crwdns2860691:0crwdne2860691:0
crwdns2860792:0crwdne2860792:0
Replace the 2.4 GHz logic board in your MacBook Pro 13" Unibody (Mid 2010) laptop and fix processing issues.
  • Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot.
A corroded, malfunctioning, or water-damaged logic board can cause unexpected shutdowns or reboots. Restore the functionality of your device with this replacement part.
crwdns2860690:0crwdne2860690:0
  • MacBook Pro 13" Unibody A1278 Mid 2010
crwdns2881795:0crwdne2881795:0
Part #:
661-5559
Model #:
A1278
Speed:
2.4 GHz
GPU:
NVIDIA GeForce 320M
MacBook Pro 13" Unibody Mid 2010
A1278 (EMC 2351) 2.4 GHz
A1278 (EMC 2351) 2.66 GHz
crwdns2881997:0crwdne2881997:0
My MacBook Pro was suffering from the same Graphics problem as many others have experienced.
I followed the instructions to take out the faulty Logic Board. Then I installed the replacement from iFixIt, with a little bit of thermal paste. Got it all screwed back together and was done in 25 Minutes. . . .
The logic board failed due to my daughter spilling milk on it. I tried to clean the board but the lactic acid managed to eat away some of the thin traces.
I ordered a replacement from iFixIt, removed the old board and installed the new one. The system booted and everything worked as expected. So f . . .
My computer’s logic board stopped working, needed to be replaced.
The repair was actually pretty easy and I felt proud of myself for the repair... and thankful for iFix :)
Always be curious (but cautious)! There’s so many things you can do on your own and save money if you take the time to researc . . .
Broken RAM sloth, so the MacBook was working a bit slow.
It went very well. The guide I used was very helpful and made the repair very easy! :)
If you just follow the guide everything goes smoothly! :)
A few weeks ago my Macbook Pro started malfunctioning and gave me a blank white screen with a flashing folder and a question mark. I was unsure what this was and after some online research I figured it may be my hard drive. I installed a new hard drive but my Mac wouldn’t see it after going into r . . .
One drop or water got to the logic board
simple replacement
keep Mac away from ANY source of moisture
crwdns2882080:0crwdne2882080:0
