crwdns2934019:0PlayStation 5 Optical Drive Laser Replacementcrwdne2934019:0
FR
crwdns2934021:0crwdne2934021:0
crwdns2931649:0#23crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
crwdns2934003:0crwdnd2934003:0Ecuvalcrwdnd2934003:0172crwdne2934003:0
(crwdns2942739:0crwdne2942739:0)
crwdns2933983:0crwdne2933983:0
Crwdns2931655:0crwdne2931655:0 unlatch the FFC connector and remove the FFC flex from the laser.
0-red-unlatch the FFC connector.
0-orange-Remove the FFC flex from the laser.
+[title] Retirer le câble plat flexible FFC du laser
+[* red] Déverrouillez le connecteur du câble plat flexible FFC.
+[* orange] Retirez le câble plat flexible FFC du laser.
crwdns2931649:0#22crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Flip over the laser module
0-black-Flip over the laser module.
+[title] Retourner le module laser
+[* black] Retournez le module laser.
crwdns2931649:0#21crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove the laser module
0-icon_note-Remove the laser module
+[title] Retirer le module laser
+[* icon_note] Retirez le module laser.
crwdns2931649:0#20crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Slide out the rod from the laser module.
0-icon_note-slide out the rod from the laser module.
+[title] Glisser la tige hors du module laser
+[* icon_note] Faites glisser la tige hors du module laser.
crwdns2931649:0#19crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove the rod retention clip.
0-icon_note-remove the clip that stops the rod from being removed.
0-icon_note-a) Use a 1.5mm slotted screwdriver to push the lower end of the clip to the left, to unhook it from the retaining hook.
0-icon_note-b) The clip should pop up.
0-icon_note-c) lift out the clip.
+[title] Retirer le clip de retenue de la tige.
+[* icon_note] Retirez le clip qui empêche le retrait de la tige.
+[* icon_note] a) Utilisez un tournevis plat de 1,5 mm pour pousser l'extrémité inférieure du clip vers la gauche, afin de le décrocher du crochet de retenue.
+[* icon_note] b) Le clip devrait apparaître.
+[* icon_note] c) Retirez le clip.
crwdns2931649:0#18crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Flip over the laser deck and move the laser motor to the side
0-icon_note-Flip over the laser deck and move the laser motor to the side
+[title] Retourner le plateau laser et déplacez le moteur du laser sur le côté
+[* icon_note] Retournez le plateau laser et déplacez le moteur du laser sur le côté.
crwdns2931649:0#17crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Flip over and remove the screw from the white plastic bracket.
0-icon_note-flip over and remove a single black screw from white plastic bracket.
0-icon_caution-Note: laser motor will be loose, so be careful when you flip over the deck for the next step.
0-icon_note-Remove the screw with a Phillips PH0 screwdriver.
0-red-black screw: 1x M1.4 x 3.9mm
0-icon_note-Remove the white bracket and set aside.
+[title] Retourner et retirer une vis noire du support en plastique blanc
+[* icon_note] Retournez et retirez une seule vis noire du support en plastique blanc.
+[* icon_caution] Remarque : le moteur du laser sera desserré, alors soyez prudent lorsque vous retournez le plateau laser pour l'étape suivante.
+[* icon_note] Retirez la vis avec un tournevis cruciforme Phillips #0.
+[* red] Vis noire : 1x M1,4 x 3,9 mm.
+[* icon_note] Retirez le support blanc et mettez-le de côté.
crwdns2931649:0#16crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove the screws holding the laser motor to the drive deck
0-icon_note-Remove the screws holding the laser motor to the drive deck.
0-icon_note-Use a Phillips PH0 screwdriver to remove the screws.
0-red-silver screws: 2x M1.7 X 3.8mm
+[title] Retirer les vis qui maintiennent le moteur du laser sur le plateau d’entraînement
+[* icon_note] Retirez les vis qui maintiennent le moteur du laser sur le plateau d’entraînement.
+[* icon_note] Utilisez un tournevis cruciforme Phillips #0 pour retirer les vis.
+[* red] Vis argentées : 2x M1,7 X 3,8 mm.
crwdns2931649:0#15crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove the metal plate over the laser motor
0-icon_note-Remove the metal plate covering the laser motor.
+[title] Retirer la plaque métallique sur le moteur du laser
+[* icon_note] Retirez la plaque métallique recouvrant le moteur du laser.
crwdns2931649:0#14crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove the screws from metal plate over laser motor
0-icon_note-Remove the screws from metal plate over laser motor.
+[title] Retirer les vis de la plaque métallique sur le moteur du laser
+[* icon_note] Retirez les vis de la plaque métallique sur le moteur du laser.
crwdns2931649:0#13crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove the laser deck
0-icon_note-Remove the laser deck.
+[title] Retirer le plateau laser
+[* icon_note] Retirez le plateau laser.
crwdns2931649:0#12crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove the screws holding the laser deck
0-icon_note-Remove the screws using a Phillips #1 screw driver.
0-red-silver screws: 4x M1.6 X 3.7mm 6.5mm head
+[title] Retirer les vis qui maintiennent le plateau laser
+[* icon_note] Retirez les vis à l’aide d’un tournevis cruciforme Phillips #1.
+[* red] Vis argentées : 4x M1,6 X 3,7 mm tête 6,5 mm.
crwdns2931649:0#11crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove the FFC cable from laser deck
0-red-Push down on the roller mech and remove the FFC cable from laser deck (near roller mech).
0-icon_note-Blunt end straight tweezers can be used to aide removal of the FFC flex. To remove the flex from the socket, pull the flex towards the rollers.
+[title] Retirez le câble FFC du plateau laser
+[* red] Appuyez sur le mécanisme à rouleaux et retirez le câble plat flexible du plateau laser (près du mécanisme à rouleaux).
+[* icon_note] Une pince droite à pointe émoussée peut être utilisée pour faciliter le retrait du câble plat flexible. Pour le retirer de son support, tirez-le vers les rouleaux.
crwdns2931649:0#10crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove the mechanism plate
0-black-Remove the mechanism plate and set aside.
+[title] Retirer la plaque du mécanisme
+[* black] Retirez la plaque du mécanisme et mettez-la de côté.
crwdns2931649:0#9crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove the screws from mechanism plate
0-black-Use a Phillips #1 screwdriver to remove the screws.
0-red-black screws: 4x M1.6 x 3.8mm.
+[title] Retirer les vis de la plaque du mécanisme
+[* black] Utilisez un tournevis cruciforme Phillips #1 pour retirer les vis.
+[* red] Vis noires : 4x M1,6 x 3,8mm.
crwdns2931649:0#8crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 flip over the assembly
0-black-Flip over the assembly.
+[title] Retourner l'assemblage
+[* black] Retournez l'assemblage.
crwdns2931649:0#7crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Disconnect FFC cable and remove the PCB.
0-red-Unlatch the wide FFC socket.
0-orange-Gently remove the wide FFC cable from the socket and set aside the PCB.
+[title] Débranchez le câble FFC et retirez le PCB.
+[* red] Déverrouillez la prise du câble plat flexible large.
+[* orange] Retirez délicatement la câble plat flexible large de la prise et mettez de côté le PCB.
crwdns2931649:0#6crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
0-black-Turn over the PCB and attached assembly.
+[title] Retourner
+[* black] Retournez le PCB et l’assemblage attaché.
crwdns2931649:0#5crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove base plate
0-black-Lift off the PCB and attached assembly from the metal plate.
+[title] Retirer la plaque de base
+[* black] Soulevez le PCB et l’assemblage attaché de la plaque métallique.
crwdns2931649:0#4crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove screws from the PCB.
0-black-Remove screws with Phillips #1 screwdriver.
0-red-black screws: 2x M1.6 x 3.8mm
+[title] Retirer les vis du PCB.
+[* black] Retirez les vis avec un tournevis cruciforme Phillips #1.
+[* red] Vis noires : 2x M1,6 x 3,8 mm
crwdns2931649:0#3crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 disconnect FFC cables and 2 wire lead
0-red-Gently pull the medium and narrow FFC flexes and the 2-wire lead from their sockets. Suitable [product|IF145-020|tweezers] (bent with points or straight blunt end) can be used to aid removal.
+[title] Déconnecter les câbles FFC et le câble à 2 fils
+[* red] Retirez délicatement les câbles plats flexibles FFC moyens et étroits, ainsi que le câble à deux fils de leurs supports. Une [product|IF145-020|pince à épiler] adaptée (courbée avec des pointes ou droite et émoussée) peut être utilisée pour faciliter le retrait.
crwdns2931649:0#2crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove top cover
0-black-Lift off the top cover.
+[title] Retirer le capot supérieur
+[* black] Soulevez le capot supérieur.
crwdns2931649:0#1crwdne2931649:0 [crwdns2931437:0crwdne2931437:0]
Crwdns2931655:0crwdne2931655:0 Remove screws from top cover
0-red-silver screws: 4x M1.6 X 3.7mm, with 6.5mm head.
0-green-black screws: 9x M1.6 x 3.8mm.
+[title] Retirez les vis du couvercle supérieur
+[* red] Vis argentées : 4x M1,6 X 3,7mm, avec tête de 6,5mm.
+[* green] Vis noires : 9x M1,6 x 3,8mm.
crwdns2931569:0crwdne2931569:0
Crwdns2931673:0crwdne2931673:0 Optical Drive Laser
Crwdns2931655:0crwdne2931655:0 PlayStation 5 Optical Drive Laser Replacement
Crwdns2931675:0crwdne2931675:0 Follow this guide to remove and replace the laser on a PlayStation 5. Before you begin, completely ***power down and unplug all cables*** from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
Crwdns2931677:0crwdne2931677:0 To reassemble your device, follow these instructions in reverse order. Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].[br] Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our [link|https://www.ifixit.com/Answers/Device/PlayStation%205|PlayStation 5 Answers community] for help.
Thing
Lentille optique laser
Title
Remplacement de la lentille optique laser PlayStation 5
Introduction
Suivez ce guide pour retirer et remplacer la lentille optique laser d'une PlayStation 5.
Avant de commencer, ***éteignez complètement votre console et débranchez tous les câbles*** de la console. N'oubliez pas de respecter les consignes de sécurité générales relatives aux décharges électrostatiques (ESD) lors de la réparation de la console.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
Déposez vos déchets électroniques chez un recycleur certifié .
La réparation ne s'est pas déroulée comme prévu ? Essayez les solutions de dépannage de base ou contactez notre communauté [link|https://www.ifixit.com/Answers/Device/PlayStation%205|Réponses PlayStation 5].
