crwdns2934019:0Nintendo Switch Right Joy Con Sensor Rail Replacementcrwdne2934019:0
FR
Crwdns2931673:0crwdne2931673:0
Right Joy Con Sensor Rail |
Crwdns2931655:0crwdne2931655:0
Nintendo Switch Right Joy Con Sensor Rail Replacement |
Crwdns2931675:0crwdne2931675:0
Follow this guide to replace a broken or faulty right Joy Con sensor rail on the Nintendo Switch game console.
***The Switch uses JIS screws. A JIS 00 driver works best, but you can also use a JIS 000 driver. If you use a Phillips driver, you'll risk stripping the screws.***
***Note:*** When you remove the shield plate, you’ll need to replace the thermal compound between the plate and the heatsink. Since normal thermal paste isn’t designed to bridge large gaps, the closest replacement is K5 Pro viscous thermal paste.
***Note:*** This guide, and the part we sell, are compatible with the original Nintendo Switch model released in 2017, as well as the newer refreshed model released in 2019 (model numbers HAC-001 and HAC-001(-01), respectively). |
Crwdns2931677:0crwdne2931677:0
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our [link|https://www.ifixit.com/Answers/Device/Nintendo%20Switch|Nintendo Switch Answers community] for help. |
Introduction |
Suivez ce tutoriel pour remplacer le rail du Joy Con droit d'une console de jeu Nintendo Switch. | | ***La Switch utilise des vis JIS. Un tournevis JIS 00 est idéal, mais vous pouvez également utiliser un tournevis JIS 000. L'utilisation d'un tournevis cruciforme en cas de besoin. Faites très attention de ne pas abîmerrisque d'endommager les vis. Les embouts cruciformes d’iFixit sont conçus pour être compatibles avec les vis de type JIS.*** | | ***Note :*** Quand vous enlevez les plaques protectrices, vous devez remplacer la pâte thermique, comme une pâte thermique ordinaire n'est pas faite pour couvrir une grande surface, la nouvelle pâte doit être un équivalent de la pâte thermique visqueuse K5 pro. | | ***Note :*** Ce tuto et les pièces que nous vendons, sont compatibles avec le modèle de Nintendo Switch sortie en 2017, mais également les nouveaux modèles de Switch sortis en 2019 (numéro de modèle HAC-001 et HAC-001(-01), respectivement). |
