Apple didn’t just announce some new electronics this year—they also unveiled a new fabric. Will it revolutionize the gadget landscape forever? Perhaps not. But it does feel pretty nice, and we thought it merited a closer look. A lot closer.
To make that happen, we’re adding a new tool to our workbench: a very fancy digital microscope, courtesy of Evident Scientific. It’s the perfect tool to take a closer look at this new-fangled FineWoven material. Join us as we zoom and enhance the new iPhone FineWoven case!
A finely woven fabric
Here’s an iPhone 15 Pro case with FineWoven fabric:
Here’s what that FineWoven fabric looks like under 52x magnification:
…and under 490x magnification:
The fabric lives up to its name—those individual fibers are fine! They measure about 6 microns thick (or 0.00024 inches)—that’s about 1/12 the width of a human hair (the pictured hair strand is 72 microns wide). Groups of these fibers make up threads that are approximately 150 microns thick. Most of us don’t have an intuitive feel of tight-woven fabric density, so for comparison: sheets made out of FineWoven fabric would have a 340 thread count, or 170 threads per inch per direction. But, that’s not really the right comparison, since each thread is made of many fibers rather than a single strand.
Apple noted that FineWoven is a microtwill. Twill is a weave that creates a pretty, diagonal pattern. We scampered around our office stealing outerwear from our team and put all the fabric we could find under the microscope in search of something similar to FineWoven. Success! The Arc’teryx Atom LT jacket and Patagonia TechFace jacket (which happens to also use recycled materials) both have similar construction.
Testing the fabric
The FineWoven fabric looks great—as long as you don’t touch it. But, what if you do? What if you scratched the fabric with a key or fingernail?
Because the weave is so tight, the FineWoven fabric should be pretty durable and tear-resistant. However, since its threads are so fine, it’s also very easy to mar the pristine weave. When we scratched the surface, the jostled threads didn’t actually break, nor was the dye damaged. Rather, the scratch-jostled fibers reflect light irregularly compared to the untouched bunches, creating a lasting visual mark. The thread itself is relatively soft, so most pocket items will leave an impression.
Will it stain, or will it be Fine?
But how do these super fine fibers handle liquids, greasy hands, or, say, hot sauce? Let’s take a look:
Coffee
The FineWoven fabric gulped down the coffee like a college student in a 7 AM class. Unlike the Arc’teryx or Patagonia jackets, the case doesn’t have a Durable Water Repellent (DWR) treatment. A DWR treatment adjusts the surface tension properties of the fabric, encouraging liquids to bead and roll off rather than soak into the fibers. The downside of DWRs is that they often contain polyfluoroalkyl chemicals (PFAs), which the EPA describes as “persistent, bioaccumulative, and toxic”.
Thankfully, the coffee evaporated from the case without leaving much of a trace.
Oil
We smushed an extra greasy finger onto the case, and the resulting mark is there to stay. The oil saturated the fibers and changed the optical qualities, resulting in a dark-looking stain. We tried scrubbing the spot with detergent and managed to lighten the spot, but it’s still visible.
Hot sauce
What if you accidentally placed the phone on a dirty table after hosting a Hot Ones party? Bad news: the FineWoven fabric can’t handle the heat. The hot sauce’s vinegar soaked in and marred the fabric.
The rest of the case
Now that we’ve completed the dirty work, let’s cut to the chase and see how it’s layered.
From exterior to interior, the case layers are stacked as follows: FineWoven fabric, gray foam, rigid plastic sheet, MagSafe hardware/white foam, another rigid plastic sheet, and finally, an inner layer of FineWoven fabric.
As expected, the FineWoven fabric layer is very thin—about 0.17 mm. Unlike leather, a woven fabric’s thickness is highly dependent on how thick the thread is. The thinner the thread, the thinner the fabric.
We burned a bit of the FineWoven fabric to suss out more of its properties. The material gave out a sweet smell and left a sticky, black, mass. This makes us think that it’s likely a polyester-based material.
The side rails look like plastic, but they actually have a FineWoven weave. The fibers have been coated with a kind of resin, resulting in a hard, non-porous surface.
End of the thread…
FineWoven is truly fine, and a really neat, high-end material, with fibers as small as 6 microns. The tight weave makes the fabric somewhat wear-resistant, but nicks and marks will show and stay. Unfortunately, without the additional protection found in technical garments like TechFace, it’s not liquid-proof. You’ve either got to be very careful with where you set the case, or treat it with a DWR or fabric protector like Scotchgard yourself.
Some more loose ends
We also tore down the iPhone 15 Pro Max and Apple Watch Ultra 2!
We snapped some high-quality imagery that might make stellar—if small— wallpapers. Don’t worry, no hot sauce in these shots. You won’t be able to feel the fabric through the screen, but these digital immortals won’t get scratched up.
crwdns2944067:022crwdne2944067:0
You should reconsider or make note when recommending DWR for these products that almost all DWRs include PFAS aka forever chemicals, that cause cancer and don’t biodegrade.
Jeff Benner - crwdns2934203:0crwdne2934203:0
But case itself is already not biodegradable, due to plastic layer and resin coated side rail...
Jindong Lee -
Hey Jeff,
That's a good callout! I added that detail in the DWR section.
Arthur Shi -
Nice presentation, thanks for putting it together. This is something that Apple should have generated!!!!
dan - crwdns2934203:0crwdne2934203:0
I agree that Apple should have put something like this together, but their presentation would have been as favorable as possible. I am glad that I Fixit did their own durability test, that way it is as neutral as possible.
Brandon L -
