Turn off the computer.
Take the slide unlocked into position, remove the battery.
Remove the 4 protective covers from the four corners of the screen using a needle or the tip of a utility knife.
After removing the 4 screws, unclip the screen frame.
Remove the screen bezel to expose the screws underneath.
Use the Phillips screwdriver to remove the 8 screws that secure the back cover.
Expose the rear cover of the screen.
Locate the flat connector for the screen.
Remove the flat connector after flipping the connector lock slightly.
Using the Philips screwdriver, loosen the 8 screws that secure the screen to the chassis on both sides.
You can now remove the screen.
To reassemble the machine, follow the above instructions in reverse order.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
