Start by unlocking the right locking latch.
Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Begin by spotting the dummy memory card.
Then, remove it and put it on your workplan.
Locate the 15 screws that hold the bottom cover of the device in place.
Unscrew them and place them on your work surface.
Then, un-clip the bottom cover, starting with the side shown in the third picture.
Unscrew the circled screws in green and red
Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
Lift the keyboard
Dans l'image, le capot inférieur est encore en place, mais dans la réalité, il aura été enlevé avant, pour laisser accès libre aux vis de fixation, en appuyant doucement au centre, cela va d'éclipser le clavier.
Bonjour,
Sur ce modèle il n'est pas nécessaire d'enlever le capot inférieur pour enlever le clavier.
Disconnect the connector circled in red in the direction of the arrow
La clavier se remet en posant sur l'avant les 2 cales (côté utilisateur) en premier, puis pivoter la clavier depuis l'avant pour abaisser l'arrière, et clipper sur la partie arrière et les côtés.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Thanks for the example. But where did you bought the keyboard? i can’t find it.
Dear Sir,
thank you for your request. We are swiss keyboards, which you can order here:
''https://whyopencomputing.ch/fr/laptop-wh...
and we have a French AZERTY here:
''https://whyopencomputing.com/fr/laptop-w...
For other keyboards, please try by your local Clevo supplier.
Best regards.
