why! N131WU Laptop: Accessing the main components
  1. why! N131WU Laptop: Accessing the main components, Remove the Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU Laptop: Accessing the main components, Remove the Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! N131WU Laptop: Accessing the main components, Remove the Keyboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! N131WU Laptop: Accessing the main components, Remove the Keyboard: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU Laptop: Accessing the main components, Remove Keyboard Connections: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! N131WU Laptop: Accessing the main components, Remove Keyboard Connections: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! N131WU Laptop: Accessing the main components, Remove Keyboard Connections: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU Laptop: Accessing the main components, Remove the upper screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 why! N131WU Laptop: Accessing the main components, Remove the upper screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
To reassemble your laptop, follow the instructions in reverse.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Felice Suglia
crwdns2935283:006/15/13crwdne2935283:0
30,908 crwdns2915208:0crwdne2915208:0
crwdns2935297:0264crwdne2935297:0
crwdns2944067:09crwdne2944067:0
Valable aussi pour le portable CLEVO N141ZU
Thomas B - crwdns2934203:0crwdne2934203:0
Merci nous avons ajouté les autres modèles compatibles
EkimiaMichel -
Bonjour MANIP pour sortir clavier, ce dernier ne vient pas ! ça tient par vis centrale VERTE impossible de le sortir sur CLEVO N141ZU précision toutes les vis sont sorties ( 10 rouges et 2 vertes ça retient vers intérieur a moins de tout casser ! ) a plus Merci Raymond Feix
Raymond Feix - crwdns2934203:0crwdne2934203:0
Si les 2 vertes sont bien retirées , il n y a aucun risque à pousser
EkimiaMichel -
Bonjour, une fois toutes les vis retirées, il faut vraiment appuyer assez fortement pour déclipser le clavier sur un côté. Pour la suite du déclipsage, il faut reprendre délicatement depuis dessus en faisant le tour du clavier depuis la partie déclipsée.
Bonne chance!
Felice Suglia - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,431
