why! L140/1PU screen replacement
  1. why! L140/1PU screen replacement, Back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 why! L140/1PU screen replacement, Back cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws.
    • Lift the cover.
  2. why! L140/1PU screen replacement, Disconnection: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 why! L140/1PU screen replacement, Disconnection: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For safety reasons, the battery must be disconnected before each intervention.
    • Disconnect the battery your fingers.
    • Other components can now be replaced safely.
  3. why! L140/1PU screen replacement, Upper frame 1: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Upper frame 1: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Upper frame 1: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The orange squares indicate the zones we will focus on.
    • Unplug the screen cable.
    • Unscrew the screw of the cover and those of the hinge. Remove the cover.
  4. why! L140/1PU screen replacement, Upper frame 2: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Upper frame 2: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Upper frame 2: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the screw of the cover, and those of the hinge. Remove the cover.
    • Unplug the Wifi cables.
  5. why! L140/1PU screen replacement, Upper frame 3: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Upper frame 3: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Upper frame 3: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the camera cable.
    • Open the two hinges.
  6. why! L140/1PU screen replacement, Upper frame 4: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Upper frame 4: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Upper frame 4: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the upper case, separating it from the screen.
    • Using a hair dryer, blow hot air around the screen to soften the frame's adhesive.
    • In order to avoid damaging components, never keep the hair dryer aimed at the same spot.
  7. why! L140/1PU screen replacement, Upper Frame 5: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Upper Frame 5: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Upper Frame 5: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the frame.
    • You can use the iFixit opening pick for this, or just your fingernails.
  8. why! L140/1PU screen replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 why! L140/1PU screen replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the upper frame of the screen.
  9. why! L140/1PU screen replacement, Lower screen 1: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 why! L140/1PU screen replacement, Lower screen 1: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two screws circled in red.
  10. why! L140/1PU screen replacement, Lower frame 2: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Lower frame 2: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Lower frame 2: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the lower frame from the screen.
  11. why! L140/1PU screen replacement, Screen 1: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Screen 1: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Screen 1: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four strips of tape.
  12. why! L140/1PU screen replacement, Screen 2: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Screen 2: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Screen 2: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, grasp and gently pull the tape.
  13. why! L140/1PU screen replacement, Screen 3: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Screen 3: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Screen 3: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the tape until it is freed. Repeat on all 3 other sides.
    • Lift up the screen.
  14. why! L140/1PU screen replacement, Screen 4: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Screen 4: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 why! L140/1PU screen replacement, Screen 4: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tape.
    • Remove the screen cable.
To reassemble your device, follow the steps in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Felice Suglia
crwdns2935283:006/15/13crwdne2935283:0
33.538 crwdns2915208:0crwdne2915208:0
crwdns2935297:0283crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 200
