Mercedes W123 Brake Fluid Flush/Bleeding
crwdns2931653:06crwdne2931653:0
Mercedes W123 Brake Fluid Flush/Bleeding: crwdns2935265:00crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  • Now open the bleed screw and watch as fluid begins to flow.
  • If you're flushing the system leave the line open until you see fresh fluid coming out. Tip - buy fluid a different color than that currently in your car. Doing so makes it very easy to tell when the fresh fluid reaches the end of the line.
  • If you're bleeding your system you'll want to leave the nipple open until you no longer see any air bubbles at all coming out of the bleed nipple.
  • Repeat steps 5 and 6 on all four wheels using the sequence noted in step 4. It's recommended to go through the entire sequence twice.
  • Be sure to keep an eye on the power bleeder during this process. Do not let it de-pressurize or run dry; either can allow air to enter the system and you'll need to start bleeding all over.
