GE Washing Machine Leaking Water Into Tub - Water Valve Replacement
crwdns2933707:0crwdne2933707:0
Remove old water valve
  • Remove the two shorter quarter inch hex head screws securing the water valve to the housing.
  • Pull each wire harness off the valve solenoids, using needle nose pliers if connectors are tight.
  • Note the color and position of each wire harness to avoid mixing them when reinstalling.
  • Slide the water valve assembly upward and away from the washer cabinet.
