Plantronics Backbeat Fit Battery Replacement
crwdns2931653:07crwdne2931653:0
Plantronics Backbeat Fit Battery Replacement, Battery Pack disassembly: crwdns2935265:00crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plantronics Backbeat Fit Battery Replacement, Battery Pack disassembly: crwdns2935265:00crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plantronics Backbeat Fit Battery Replacement, Battery Pack disassembly: crwdns2935265:00crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  • With the battery pack removed from the earpiece surround, you can work on the battery pack disassembly.
  • Start by gently prying back the red tangs of the red sleeve and pushing the battery pack out of the housing. The read sleeve will slide off as well as a black silicone sleve.
  • To remove the PCB from the battery, carefully cut the double sided tape underneath the board on the side away from the soldered joint.
  • Once you are close enough to the solder joint and board is flexing a little, desolder while gently prying the board up and away. This may take several heat and flex cycles to fully pull it away. Repeat this process for the other side.
  • By this point, the PCB should be free of the battery.
