Razer Basilisk V3 LED Replacement
crwdns2935425:01crwdne2935425:0
crwdns2931653:01crwdne2931653:0
Razer Basilisk V3 LED Replacement: crwdns2935265:00crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  • Heat the soldering iron to middle high heat.
  • The soldering iron can burn when heated. Use caution when using. For more information on using a soldering iron, take a look at How to Solder and Desolder Connections
  • Inject a small amount of flux onto the LED solder connection you wish to replace.
  • Place the solder wick on top of the solder joint.
  • Press the soldering iron on top of the solder wick on top of the solder joint, and press until you see the solder come through the wick.
  • Once you see the solder through the wick (it should look silver and not copper colored) pull the wick off the solder joint and remove the soldering iron.
  • Repeat on the 3 other solder joints for the LED.
  • Remove the LED with tweezers.
