Kobo Libra Colour 마더보드 교체
Kobo Libra Colour Motherboard Replacement, Disconnect the interconnect cable: crwdns2935265:00crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kobo Libra Colour Motherboard Replacement, Disconnect the interconnect cable: crwdns2935265:00crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kobo Libra Colour Motherboard Replacement, Disconnect the interconnect cable: crwdns2935265:00crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  • Use the tip of a spudger to lift up the locking tab on the ZIF connector.
  • Use tweezers, or your fingers, to grip the blue pull tab on the interconnect cable and disconnect it.
  • During reassembly:
  • Inspect the ends of the cable and the ZIF connectors for any remaining coating that could prevent a good connection.
  • Peel off the coating, heating the cable and the ZIF connector when the coating becomes too brittle.
  • It doesn't have to look pretty! You just need to remove enough coating to have the cable sit properly in the connector.
스퍼저의 끝을 사용하여 ZIF 커넥터의 잠금 탭을 들어 올리세요.
핀셋이나 손가락을 사용하여 인터커넥트 케이블의 파란색 당김 탭을 잡고 연결 해제하세요.
재조립할 떄:
케이블 끝과 ZIF 커넥터의 연결 상태를 방해할 수 있는 코팅이 남아 있는지 검사하세요.
코팅이 너무 부스러지면 케이블과 ZIF 커넥터를 가열하여 코팅을 벗겨내세요.
예쁘게 보일 필요는 없습니다! 케이블이 커넥터에 제대로 장착될 수 있을 만큼만 코팅을 벗겨내면 됩니다.
[title] Disconnect the interconnect cable
[* black] Use the tip of a spudger to lift up the locking tab on the ZIF connector.
-[* black] Use tweezers, or your fingers, to grip the blue pull tab on the interconnect cable and disconnect it.
+[* black] Use [product|IF145-020|tweezers], or your fingers, to grip the blue pull tab on the interconnect cable and disconnect it.
[* icon_reminder] During reassembly:
[* black] Inspect the ends of the cable and the ZIF connectors for any remaining coating that could prevent a good connection.
[* black] Peel off the coating, heating the cable and the ZIF connector when the coating becomes too brittle.
[* icon_note] It doesn't have to look pretty! You just need to remove enough coating to have the cable sit properly in the connector.
