crwdns2931527:0crwdnd2931527:0crwdnd2931527:0crwdnd2931527:0crwdne2931527:0
crwdns2935425:016crwdne2935425:0
crwdns2931653:016crwdne2931653:0
After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
Remove the film from the 15 strip by reaching in from above and pulling the tab straight up from the bottom edge of the display.
- | [* icon_caution] ***Do not ***fully lower the display in this step; there are still two cables that must be attached. Once you've set the display down, you won't be able to lift it again without damaging the adhesive. |
- | [* black] Lay the bottom edge of the display glass against the top of the lower bezel. Be sure to align the edges of the display with the edges of the rear case. |
+ | [* icon_caution] Verify that your iMac is turned off and unplugged from power before you continue. |
+ | [* black] After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward. |
+ | [* black] Remove the film from the 15 strip by reaching in from above and pulling the tab straight up from the bottom edge of the display. |
