Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546
crwdns2931527:0crwdnd2931527:0crwdnd2931527:0crwdnd2931527:0crwdne2931527:0
crwdns2936317:0crwdne2936317:0
crwdns2931653:014crwdne2931653:0
iMac Intel 27" EMC 2546 Adhesive Strips Replacement: crwdns2935265:00crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac Intel 27" EMC 2546 Adhesive Strips Replacement: crwdns2935265:00crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac Intel 27" EMC 2546 Adhesive Strips Replacement: crwdns2935265:00crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
  • If you've already verified that your iMac is working correctly and are ready to seal it up, skip to Step 16.
  • Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
  • Flip the display data connector lock down onto the socket.
  • Insert the display power connector into its socket on the logic board.
Décollez et retirez la protection des bandes 15 et 14 sur l'écran.
-[* black] Peel up and remove the backing from strips 15 and 14 on the display.
+[* icon_note] ''At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.''
+ [* black] If you've already verified that your iMac is working correctly and are ready to seal it up, skip to Step 16.
+[* black] Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
+[* black] Flip the display data connector lock down onto the socket.
+[* black] Insert the display power connector into its socket on the logic board.
