MacBook Pro 14" 2021 스크린 교체
crwdns2935425:017crwdne2935425:0
crwdns2931653:017crwdne2931653:0
MacBook Pro 14" 2021 Screen Replacement: crwdns2935265:00crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Screen Replacement: crwdns2935265:00crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  • During reassembly, follow these instructions to align your screen hinges:
  • If you have blue threadlocker, apply a drop to each screw's threads to prevent them from loosening over time.
  • Install the hinge screws without fully tightening them. Center the hinges and check for gaps or rubbing on either side.
  • Fully tighten the hinge screws.
  • If your screen clicks or snaps when it's opened or closed, loosen the screws and realign the screen.
재조립하는 동안, 일단 힌지 나사는 조이지 말고 설치하세요. 그런 다음 스크린을 올바로 중앙에 배치하고 양쪽에 정렬될 때까지 조절하세요. 끝으로, 나사를 조이세요.
스크린을 열 때 딸깍 또는 딱 거리면 힌지 나사를 풀고 정렬을 조절하세요. 스크린이 너무 앞쪽으로 위치하지 않도록 확인하세요. 열고 닫을때 스크린이 본체에 걸릴 수 있습니다.
원하는 경우, 나사산에 파란색 나사고정제를 약간 추가하여 시간이 지나도 느슨해지지 않도록 하세요.
-[* icon_reminder] During reassembly, first install the hinge screws without tightening them fully. Then adjust the screen until it is correctly centered and aligned on each side. Finally, tighten the screws.
-[* icon_reminder] If your screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
-[* icon_reminder] If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
+[* icon_reminder] During reassembly, follow these instructions to align your screen hinges:
+ [* icon_note] If you have blue threadlocker, apply a drop to each screw's threads to prevent them from loosening over time.
+ [* black] Install the hinge screws without fully tightening them. Center the hinges and check for gaps or rubbing on either side.
+ [* black] Fully tighten the hinge screws.
+ [* black] If your screen clicks or snaps when it's opened or closed, loosen the screws and realign the screen.
