PowerBook 2400c Disassembly
crwdns2931653:012crwdne2931653:0
PowerBook 2400c Disassembly, Remove system board assembly: crwdns2935265:00crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PowerBook 2400c Disassembly, Remove system board assembly: crwdns2935265:00crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PowerBook 2400c Disassembly, Remove system board assembly: crwdns2935265:00crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  • Remove the 2 silver 3.5mm phillips screws from the shielding on the right of the board. You can then remove and set aside the shielding.
  • Remove the 3 remaining silver 3.5mm phillips screws from the system board.
  • Remove the 2 black 16mm phillips screws from the right of the board.
  • Remove the 1 silver 14mm phillips screw from the center of the board.
  • Using a spudger, disconnect the audio cable from the board.
  • Carefully remove the audio port cover by gently twisting upward and lifting out.
  • The main system board is connected to the daugter board below. Using a spudger where indicated to gently coax the board free from the connector below.
  • You can now lift the main board out of the case.
