Makita Circular Saw HS7601J Flex Replacement
crwdns2931653:06crwdne2931653:0
Makita Circular Saw HS7601J Flex Replacement, Termination cable: crwdns2935265:00crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Makita Circular Saw HS7601J Flex Replacement, Termination cable: crwdns2935265:00crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Makita Circular Saw HS7601J Flex Replacement, Termination cable: crwdns2935265:00crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
Termination cable
  • Before you do anything else with the cable, reattach the flex protector (the rubber sheath that protects the flex from bending. For terminating the brown wire, place the crimp on the wire over the screw hole, place the brass piece on the screw and place the screw roughly in the hole and use a philips screwdriver to tighten it.
  • Make sure the screw is not loose and is fairly tight as you don’t want this coming loose again. For the blue wire, loosen off the screw in the white connector using a 3.5mm screwdriver all the way and slide the blue cable in till there is no copper showing and make sure no strands are showing as well then tighten.
