Makita Circular Saw HS7601J Flex Replacement
Makita Circular Saw HS7601J Flex Replacement, Preparing to bare cable: crwdns2935265:00crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  • For this step you will need to source a replacement flex for the saw, the saw does not require an earth so a two core flex will be acceptable. The diameter of the wire can be 1mm-1.5mm. The length of the flex can be whatever you want it to be but I suggest a similar length to what it was originally.
  • If you can’t get a replacement flex with a moulded plug top, you will need to source a new plug top as well. The replacement flex I had to hand had a moulded plug top so I won’t be showing how to wire one here.
  • For this step you will also need a crimp that has a similar size of hole to the one that was originally on the cable. You will also need a crimping tool to crimp the wire and a pair of side cutters and a sharp knife to bare the cable and prepare it for termination.
