MacBook Pro 16" 2019 스크린 교체
crwdns2931653:07crwdne2931653:0
MacBook Pro 16" 2019 Screen Replacement: crwdns2935265:00crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 16" 2019 Screen Replacement: crwdns2935265:00crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  • Disconnect all three antenna cables by prying each one straight up from its socket.
  • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
  • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
안테나 케이블 세 개를 모두 소켓에서 똑바로 들어 올려 분리하세요.
핀셋 또는 spudger/스퍼저의 평평한 끝을 각 케이블 아랫면에 넣어 소켓 근처까지 밀어 넣은 다음 살살 비틀거나 들어 올려 분리하세요.
각 케이블을 다시 연결하려면, 커넥터를 소켓 바로 위에 맞춘 다음 아래로 눌러서 제자리에 끼우세요.
[* black] Disconnect all three antenna cables by prying each one straight up from its socket.
- [* black] Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
+ [* black] Slide your [product|IF145-020|tweezers] or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
[* icon_reminder] To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
