IKEA KOPPLA Connector (fix)
IKEA KOPPLA Connector (fix), Fixing the issue (broken solderpoints): crwdns2935265:00crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IKEA KOPPLA Connector (fix), Fixing the issue (broken solderpoints): crwdns2935265:00crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  • Resolder all the USB connector pins (red box'es), on all 3 USB connectors to be sure they are functional. (on this image the top one is defective)
  • The reason solder points break is the connector support is soldered onto the board on one side only. Not by the arrow. Thereby adding stress directly to the soldered pins.
  • In addition the connector pin (square) near the U2 marking is too short and therefore may not be soldered properly.
  • see 2nd image for example of front support pin is pulled out of solder area.
  • Note that the board on the newer 'Smahagel' model of this charger, which has a 100-240V voltage rating but otherwise looks identical externally, looks slightly different and has both supports soldered to the PCB. The fix still applies though.
